Author Topic: Ready and power blinking  (Read 7381 times)
ohara
« on: May 15, 2004, 08:48:21 pm »
Ready and power blinking what causes this I can not find my O M booklet. Hot Springs Grandee. Shouls I keep Power to the spa
Re: Ready and power blinking
« Reply #1 on: May 16, 2004, 12:19:54 am »
I was too tired to look further, but try this
http://www.hotspring.com/Customer/owner_manual.html
tjr
« Reply #2 on: May 18, 2004, 09:44:10 pm »
If it is a 2003 or 2004 grandee, the heater pressure switch is signaling low flow. If you just did a water change the circ punp might be air locked.
Rich
« Reply #3 on: May 20, 2004, 01:39:33 am »
Ready flashing should be problem with temp sensor. Power flashing should be over temp setpoint reached or if GFI breaker was tripped and when you reset it you didn't leave it off for required time before turning it back. Time is like 30 or 60 secs. Probably both have to do with temp, if sensor failed high or if air in system could be cause. Was tub just filled. If so I would turn off power so they reset, reset thermal on heater and then reenergize and try to flush air out of system with pumps as per fill procedure. Rich
Rboehme
« Reply #4 on: June 09, 2004, 10:07:52 pm »
This is why having a customer service oriented dealer is very important.
« Reply #5 on: June 10, 2004, 06:21:29 am »
If both flash, it means the circ pump has failed, or is blocked.
Turn off the power for a minute, then restart spa. If that doesn't do it, Call your dealer.
