Author Topic: thermostats  (Read 1992 times)
morax
thermostats
« on: March 12, 2007, 04:56:22 pm »
is there an adjustment to set the in thermostat toadjust the no. of degree before it turns on the heater from the setting ie. 103 is selected i want it to turn heater on at 101
thermostats
stuart
Re: thermostats
« Reply #1 on: March 12, 2007, 09:43:19 pm »
Good question...Depends on the type of spa. Some of systems like the Balboa M7 have sensors at the entry and exit of the heater and look for a difference in temp between the two however the sensitivity of the probe is what you seem to be asking.
The older thermostats might do that but you can't really set it. Most of the current systems are accurate within at least one degree.
So the answer to your question is no...you can't calibrate a large difference between your thermostat and your temp sensor on most spas without causing failure messages.
Re: thermostats
