Author Topic: What causes are there for PH to drop in hot tub  (Read 11487 times)
teach
« on: January 20, 2007, 07:05:53 pm »
I have never really had muchof a  problem with keeping my tub water balanced, but recently over the past month I have noticed that the Ph always seems to be much lower than it usually is....having to add PH increaser alot on a weekly basis.   What causes PH to drop?
Chad
  • 2006 Jacuzzi J-345
Re: What causes are there for PH to drop in hot tu
« Reply #1 on: January 20, 2007, 07:08:17 pm »
Are you using an unbuffered mps and what is your TA?
What is your primary sanitizer?
Sorry for all the q's. :D
« Last Edit: January 20, 2007, 07:42:50 pm by WHY_NOT »
DrOperations
  • Royal Spa Emperor II
« Reply #2 on: January 20, 2007, 07:41:11 pm »
I, too, have the similar experience.  I use Leisure Time's Renew MPS.  I don't know if it is buffered or not.  Anyone know?
Chad
« Reply #3 on: January 20, 2007, 07:43:19 pm »
It's buffered.
teach
« Reply #4 on: January 21, 2007, 08:03:17 am »
I use oxyspa,100% pure DuPont® Monopersulfate Compound (spa activatior) which is a MPS ,I order from Spa Depot on the internet, I believe it is buffered, as my primary sanitizer.  My tub uses a Silver Iodine cartridge inside spa filter and Ozone. Once a week I use 3 oz of activator as a shock and sometimes ocassionally substitute Sodium Dichlor instead of the activator as the shock.  Water is usually always very clear, but the PH seems  to be very low each week I test it.   I know I could do a water change, but its freezing cold here and would like to put that off till warmer weather.  Just wondering about the low PH?
Chad
« Reply #5 on: January 21, 2007, 10:18:30 am »
The Oxyspa mps is definetly not buffered, has no sanitizing capabilities, and is the cause for your constant addition of alk/ph increaser. Mps is purely an oxidizer. The only primary sanitizers I know of are chlorine and bromine, all other things like ozone and  mineral catridges should only be used as a secondary sanitizer in conjuction w/ chl or br.
Would I be correct in saying that some weeks there is no addition of chlorine to your water?
How long have you been using your current system/routine?
« Last Edit: January 21, 2007, 10:23:41 am by WHY_NOT »
« Reply #6 on: January 21, 2007, 04:10:06 pm »
Always adjust Alkalinity before pH. There's no use attempting to raise pH if your alk is low.
