Author Topic: Bromine and Chlorine  (Read 11117 times)
sz22
« on: December 14, 2006, 06:50:43 pm »
I am a first time spa owner and whats the difference between bromine and chlorine and which is better
hottubdan
Re: Bromine and Chlorine
« Reply #1 on: December 14, 2006, 07:05:59 pm »
For a spa, chlorine comes as a powder.  Bromine is delivered as a tablet, pillow or nugget, in a floating dispenser.
For bromine, you load your floater, add an activating product and adjust weekly.
With chlorine you add each time you use the spa.
There are advocates for each product.  Neither is better.  Different strokes for different folks.
Welcome to Spatopia! :D
sz22
« Reply #2 on: December 14, 2006, 07:08:03 pm »
Is it dangerous to put bromine in a chlorine spa?
hottubdan
« Reply #3 on: December 14, 2006, 07:27:07 pm »
Nope.  It is dangerous to mix bromine tabs and chlorine tabs in a floater.
If you add bromine to a tub on chlorine, it will become a brominated tub.
Are we confused yet? :D
bosco0633
  • Look into my eyes
« Reply #4 on: December 14, 2006, 10:44:45 pm »
dont mix.  query these topics and you will find lots of reading.
Best line was already stated, different strokes for different folks.
Dr. Spa™ Ret.
« Reply #5 on: December 14, 2006, 11:05:55 pm »
Everything you want to know about bromine;
http://www.rhtubs.com/BROMINE.htm
Everyhting about chlorine (too much);
http://www.rhtubs.com/chlorine.htm
Gomboman
  • My Pride and Joy
« Reply #6 on: December 14, 2006, 11:52:00 pm »
What do you use at home doc?
« Last Edit: December 14, 2006, 11:52:22 pm by Gomboman »
Bama
« Reply #7 on: December 15, 2006, 12:04:40 am »
I learned from folks on this website to use diclor after each use.
It has worked like a charm!  However, when I left town for 2 weeks, I through in the spa frog filled with bromine and minerals.  When I got back, all my readings of the test strip were fine.
So, now I have bromine and chlorine in my spa.  I don't think it's a problem, but maybe someone else should answer that.  All I know is, my test strip readings are all golden.
Dr. Spa™ Ret.
« Reply #8 on: December 15, 2006, 12:12:58 am »
You most likely have a bromine spa now bama. Any chlorine you add just reactivates the bromine.
Gomb, personally, I use a combination of a passive copper ion system with occasional chlorine. Typically I use the sauna first, then rinse off with a bucket of hot tub water. I kinda figure there isn't much "dirt: getting into the water.
« Last Edit: December 15, 2006, 12:14:18 am by lets »
Gomboman
  • My Pride and Joy
« Reply #9 on: December 15, 2006, 12:33:57 am »
Very interesting doc. Can you give us more information on the passive copper ion system? I'm not familiar with that system.
Dr. Spa™ Ret.
« Reply #10 on: December 15, 2006, 12:53:31 am »
Not without opening my self up to 6 figure fines from the EPA (yes, they've visited me and warned me). As it's not EPA approved, it's not something I can recommend  ;)
I can tell you though, that my hot tub is heated by a coil of copper pipe running around the inside the tub. Hot water from my water heater is thermostatically pumped through the pipe for heat.
« Reply #11 on: December 15, 2006, 04:22:25 am »
Yea...right, and then it goes through a condensor and the results drip out this little tube....sure thing doc.
Dr. Spa™ Ret.
« Reply #12 on: December 15, 2006, 09:00:01 am »
????????? Huh? Is there something you're questioning?
But, now you got me thinking.............. Wonder if there's a way to use a hot tub as a still?  ;D
sledjunkie
« Reply #13 on: December 15, 2006, 09:16:06 am »
On that note has anyone tried a copper ion system? Like Clearwater Blue?
If so can you provide any feedback, both positive and/or negative?
Looking for first hand experience. thanks
spa_dr.
  • hmmmm,  hot tubs , DOH!
« Reply #14 on: December 15, 2006, 03:49:02 pm »
hey, I know you. your supposed to be an expert on this stuff..... better keep studying. the Bioguard encyclopedia will answer these questions for you. show some initiative and study study study
