Author Topic: 2006 Optima Electrical Question  (Read 4053 times)
vanduse1
« on: September 06, 2006, 12:09:03 pm »
I have a 2006 sundance optima that was delivered and installed with a 50A configuration.  I have thought about upgrading my breaker to 60A (My wiring is sufficient).  I believe I need to change a jumper on the Optima in order for it to use the extra Amperage.  Could anyone help me with the correct change/configuration to do this?  Thanks!
Reese
Re: 2006 Optima Electrical Question
« Reply #1 on: September 06, 2006, 12:20:36 pm »
Go to the rhtubs.com site and check their forum.  N1oty posted the Sundance/Jacuzzi jumper information a few months ago.  Couldn't your dealer supply you with this info?
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #2 on: September 06, 2006, 01:51:53 pm »
There needs to be a jumper on JP9-7 to take advantage of the 60amp features.   There should already be a jumper on JP9-9, so the one above that is the one you need to put the jumper on.
vanduse1
« Reply #3 on: September 06, 2006, 01:55:21 pm »
I assumed there was one needed on JP9-7.  However, I do not know what one I can remove.  Any ideas?
SerjicalStrike
« Reply #4 on: September 06, 2006, 03:08:20 pm »
There is usually a spare jumper at the top either across JP9-1 or just on one side of it.  That one can be used.  If there is not an extra jumper, use the jumper on JP9-5.  Removing that one won't really do anything.
pg_rider
  • I've been Optima-ized
« Reply #5 on: October 24, 2006, 09:47:47 am »
Can anyone tell me if mine is jumpered correctly?  Electrician is coming shortly and I want to make sure this is right!  The delivery guy configured it but he seemed a little unsure of himself.  I see that JP9-7 is jumpered, but what about the rest of the pins?  Do they look correct?  JP9 has pin 1 jumpered to 3, has 7 jumpered, has 9 jumpered, and JP19 and 20 don't have anything.
« Last Edit: October 24, 2006, 10:48:44 am by pg_rider »
Paul G.
2006 Sundance Optima
vanduse1
« Reply #6 on: October 24, 2006, 10:31:40 am »
I am fairly sure your setup is correct.  The jumber that connects 1 to 3 is just an extra jumper being 'stored' for later use.  I did the conversion to 60A and it is great that the heater will stay on with all the jets and blower running.
Enjoy the tub.  It is fantastic!
pg_rider
« Reply #7 on: October 24, 2006, 01:40:32 pm »
Thanks for the reply.  Everything seems to be working -- turned on both pumps and the heater icon stayed lit. :)
Paul G.
