Author Topic: Hey, Pool People I Need Your Help ...  (Read 4494 times)
« on: June 03, 2007, 11:58:32 am »
I have an above ground pool and I opened this year and last year to a stained pool wall where the water line for the winter was. It is greenish and didn't come off when I brushed the sides. Both years I opened the pool to no stabilizer although I closed the pool and I did have stabilizer in the water.
Upon opening and refilling my water had no stabilizer. low PH and alkalinity and probably low calcium.
I have shocked the pool with at least 8PPM chlorine (with 0 stabilizer) and it didn't go away. I used the magic eraser at the suggestion of Bonibelle and it didn't do anything (sorry Boni!).
Any suggestions on what to use? I am thinking there may be something to pour into the water that will lift the stain.
Any suggestions? This better not ever happen to my spa!
Bonibelle
  • '05 Marquis Epic
Re: Hey, Pool People I Need Your Help ...
« Reply #1 on: June 03, 2007, 04:09:28 pm »
Wow Vinny, I'm surprised, the magic eraser cleaned my neighbor's ring and it was really disgusting!  I know in the past we have used chlorox clean up spray and a spa mit to clean the ring around the pool, but I think that our stain was probably from suntan lotion. Maybe if you can drop your water level to just below the stain and try Chlorox.  ;). If it's an algae type stain the bleach should get rid of it.
 To be honest, I think you are not scrubbing hard enough..so get back in there and use a little elbow grease! ;D ;D
« Reply #2 on: June 03, 2007, 04:24:38 pm »
That stain is from where the winter water level was to the floor ... I would have to empty my pool! :o
I really did try hard, even used my foot and the sponge on the bottom of the pool. I thought that the chlorine would have worked with the original shock of at least 8 PPM and it being there most of the night. I tested my water in the AM after putting the bleach in in the PM and it measured about 5 PPM. I would think that it would have been bleached out.
Bonibelle
  • '05 Marquis Epic
« Reply #3 on: June 03, 2007, 06:12:26 pm »
Sorry, Vinny, I misunderstood, I thought the stain was at the water mark. I don't think the eraser works well underwater.  :-/
Pathfinder
« Reply #4 on: June 03, 2007, 06:28:14 pm »
What we use for those kinds of stains on openings  are one of those normal kitchen type scrubbers where you can pour liquid into the handle and it comes out the end. Depending on the type of stain  we use either some stain prevent product, algaecide, or tilex for stairs.  They can be bought at any grocery store or walmart. They wont scratch the liner either.
« Reply #5 on: June 03, 2007, 07:18:24 pm »
Thanks for the info!
Which should I try first ... I'm thinking stain preventer. Algecide may not be the thing since I have brushed the pool wall and it has been sitting in chlorinated water.
Pathfinder
« Reply #6 on: June 03, 2007, 09:16:56 pm »
you may not have to use anything  at first   try it without then I would go with the stain prevent.  If it doesn t come off let me know  there are a couple of concoctions I have made up b4 that are pretty strong.
« Reply #7 on: June 03, 2007, 09:21:27 pm »
Thanks!
I "know" I need something since the magic eraser didn't work. I'll try the stain preventer first, probably not until next weekend. I even tried a brush other than the pool brush and nothing.
« Last Edit: June 03, 2007, 09:22:29 pm by Vinny »
In Canada eh
« Reply #8 on: June 04, 2007, 05:19:00 pm »
    Our dealer sells a vinyl cleaner called "Amaze" that really works on the gunk above the water line and the couple of plastic tables and chairs that we have.   Not sure what name it would be marketed under in the USA but, maybe you could try some of it in Pathfinders kitchen/pool scrubby
Bullfrog 451
Pathfinder
« Reply #9 on: June 04, 2007, 07:01:12 pm »
I do use it in the scrubbers it is a good product produced by Sani Marc which carries different names Like "Amaze" which is labeled for the IPG buying group.  It works awesome for above water surfaces but when its under the water now it is not very effective.  As far as I know Sani Marc does not distribute pool and spa products to the US.
« Last Edit: June 04, 2007, 07:02:16 pm by Pathfinder »
