Author Topic: Pouringa pad....Flat????  (Read 5655 times)
hottbpete
  • Caldera Niagara
« on: September 12, 2006, 08:54:41 pm »
We are going to be pouring a pad for the Hot Tub and want some info if we should be pouring it flat or with a pitch to move the water off the pad?
And is there is a pitch....how much....and then you should shimm right? :o
barshnik
Re: Pouringa pad....Flat????
« Reply #1 on: September 12, 2006, 09:02:01 pm »
I think most newer spas like to be flat if there are dual filtration chambers involved - I know the book that came with my Artisian says 'level'.
That being said, my pad has just a tiny pitch, maybe 1/2" for 8'.  Don't know if I like the idea of shimmimg - an awful lot of water weight for the spa frame/shell to support.
John F
Amanda_Panda
  • Clearwater
« Reply #2 on: September 12, 2006, 09:04:02 pm »
Definately flat. I believe you can get away with about 1/2" over 8' but I would try to avoid that.
The best intention pales in comparison to the smallest good deed.
DPS
  • The light was yellow, sir
« Reply #3 on: September 12, 2006, 09:08:42 pm »
How large of a pad are you pouring?  If it is just large enough for the spa or the spa and it's steps, I would pour it as level as possible.  If it is a large patio you may want a little slope for run off.  Even then, I would try to get the part where the spa will sit level.
It is usually a bad idea to try and shim the spa level on a sloping slab.  If you raise one end an inch the center is up one half inch.  The 2400 to 4000 puonds of water will weight it down to the slab and eventually cause structural problems with the spa.
Cola
  • Time for bed kids
« Reply #4 on: September 12, 2006, 10:55:06 pm »
I'm no concrete guy, but mine is flat an level to within 1/16" over 8 feet.
Go flat or go home, er, uh, just go.
alwaysperky
  • Hail the flashlight king!
« Reply #5 on: September 13, 2006, 08:11:57 am »
Flat.
I did mine with a slight slope, as you might do with a patio.  I like how the rain drains, etc., but it is something "I" notice since the water is about a half inch lower on one end.
hottub.pool_boy
« Reply #6 on: September 13, 2006, 08:35:24 am »
Pour it perfectly flat and LEVEL. No, water is not going to collect under your spa and rot it. JUST POUR IT LEVEL.
sledjunkie
« Reply #7 on: September 13, 2006, 08:50:37 am »
level
Zep
  • Cal Spas SQ92 Dallas-Texas
« Reply #8 on: September 13, 2006, 08:54:53 am »
[size=18]mine is flat[/size]
Step 1
Step 2
Step 3
Step 4....and as you can see..."flat" no more!....lol..... ;)
lagator43
  • My wings are a shield of steel.
« Reply #9 on: September 13, 2006, 09:46:20 am »
Step 1
Step 2
Step 3
Your hot tub looks awesome! ;)
« Reply #10 on: September 13, 2006, 10:00:28 am »
Zep, haven't you told the bathers of your tub yet that wearing swim suits is horrible for the water and could possibley pose some health risk?  ;)
« Last Edit: September 13, 2006, 10:00:43 am by drewstar »
Dr. Spa™ Ret.
« Reply #11 on: September 13, 2006, 10:29:25 am »
Swim suits can also scratch the spas surface.
tanstaafl2
« Reply #12 on: September 13, 2006, 02:33:58 pm »
I had a large concrete pad poured under my deck at the time the house was built with the intent of eventually getting a spa but did not think about the pitch at the time (a lot to think about when building a house and that one slipped through!). So the builder put a slight pitch on it away from the house. I am kind of glad they did now but felt it was too much for my spa and so I resolved it with a giant concrete shim as it were.
If you are pouring a pad much larger than the spa itself and want it to have a little pitch but want the area of the spa to be flat this provides one option to do that.
http://www.whatsthebest-hottub.com/cgi-bin/yabb/YaBB.pl?num=1143231808/0#0
vblv
« Reply #13 on: September 13, 2006, 03:42:31 pm »
Our pad is being poured next week. It's larger than the spa, so it will have a pitch EXCEPT the area that the spa will sit on will be level. Our dealer said absolutely no pitch.
TN__HOT_TUB
« Reply #14 on: September 13, 2006, 04:29:48 pm »
Correct.  Protect the spa's surface.
« Last Edit: September 13, 2006, 04:30:13 pm by TN__HOT_TUB »
