Sign up
Log in
It's HOT...
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to our forum.
Home
Help
Search
Login
Register
Original
Leveled cement (Pictures added).
« previous
next »
Print
Pages: [
1
2
Author
Topic: Leveled cement (Pictures added). (Read 6756 times)
cooltoy2000
Senior Member
Go Flames Go!!!
on:
June 29, 2006, 10:59:11 am »
Hello.
This would be my first post, but I have been reading this forum for about a month. The reading was very helpful in choosing my first tub. I chose the Hot Spring Vanguard, which should be delivered in a week or so.
I planned for this day eight years ago, when I first poured the cement pad for the tub. I was doing some measurements on the pad a couple of days ago and realised that the pad was slightly off level. It is tilted forward a couple of degrees.
Is that an issue? Do I need to level it before the tub goes in? If so what is the best way to do that - leveling cement?
Thanks for your help.
Last Edit: July 15, 2006, 01:23:40 pm by cooltoy2000
Logged
on:
JeffB
Junior Member
I love YaBB 1G - SP1!
Re: Leveled cement.
Reply #1 on:
June 29, 2006, 11:10:51 am »
I had a cement pad put down last fall. It has a slight tilt for water runoff. I can't remember exactly the amount of tilt-maybe an inch or inch and a half from side to side. My new tub was installed last friday with no shims and no problems. Any lack of levelness in the water line is unnoticable. I didn't like the idea of shims and decided in advance I would live with an unlevel water line, but if it is not level, it is not noticable. Also, I think you want some tilt with your cement pad so water will run off and not pool. Hope this helps.
Logged
Mentor Level Member
Re: Leveled cement.
Reply #2 on:
June 29, 2006, 11:11:29 am »
What is the drop, over how long?
(ie: it drops .25" over 8 feet).
you poured the pad 8 years ago?
Should be just about cured.
Last Edit: June 29, 2006, 11:12:15 am by drewstar
Logged
cooltoy2000
Senior Member
Go Flames Go!!!
Re: Leveled cement.
Reply #3 on:
June 29, 2006, 11:23:33 am »
I do not like the idea of shims either.
I will check on the amount of drop when I get home tonight.
Logged
galen
Full Member
Maxxus
Re: Leveled cement.
Reply #4 on:
June 29, 2006, 12:07:15 pm »
I would not be concerned with an inch or so. If it was more then you may notice it. Mine has an 1 1/2 slope with no effect to the tub.
Logged
Mentor Level Member
Re: Leveled cement.
Reply #5 on:
June 29, 2006, 12:16:42 pm »
The idea of shims also doesn't appeal to me.
Persoanlly for me, I wouldn't want more than a .25" drop across the tub This can effect the jets not being submereged and looks funky as well.
I don't know what the tolereances that manufactuer's state. But if you do have a significant slope (they say some slope is good for water run off) folks in this forum have talked about "mud jacking"; injecting cement under the pad to raise it to the correct slope., or simply just pouring a new top coat on the pad and correcting the slope.
Logged
Ultimate Member
Lead me not into temptation- I can find it myself!
Re: Leveled cement.
Reply #6 on:
June 29, 2006, 01:49:06 pm »
There are leveling products that can be used to level off concrete. Not exactly cheap, but they work well.
Logged
cooltoy2000
Senior Member
Go Flames Go!!!
Re: Leveled cement.
Reply #7 on:
June 29, 2006, 04:06:50 pm »
How fast do they set, I only have a week before the tub arrives?
Logged
Ultimate Member
Re: Leveled cement.
Reply #8 on:
June 29, 2006, 04:39:25 pm »
The one I used was to level a section of basement concrete for a shower pan, if I recall, it setup and was ready for use in a day or so. Unless the slab is way off, the coating to level will be pretty thin, and set rather quickly.
Logged
cooltoy2000
Senior Member
Go Flames Go!!!
Re: Leveled cement.
Reply #9 on:
June 29, 2006, 04:47:15 pm »
Thanks.
This is the same stuff I was thinking off. Darker grey in colour, my builder used it to level the flour toward the drain. But will it stand up to outdoors?
Last Edit: June 29, 2006, 04:47:37 pm by cooltoy2000
Logged
Cola
Full Member
Time for bed kids
Re: Leveled cement.
Reply #10 on:
June 29, 2006, 04:53:42 pm »
Don't use the leveling products if you have frost in the winter.
Logged
cooltoy2000
Senior Member
Go Flames Go!!!
Re: Leveled cement.
Reply #11 on:
June 29, 2006, 05:02:05 pm »
How does -30°C sound.
Logged
cooltoy2000
Senior Member
Go Flames Go!!!
Re: Leveled cement.
Reply #12 on:
July 06, 2006, 09:38:21 pm »
So my new Vanguard was delivered today.
Turns out the pad was not only tilted forward but a bit sideways two (towards one corner).
So they had to shim the tub, good thing I chose Hot Spring and shimming is possible.
Got her filled up and heating. Hoping to use it for the first time tomorrow night.
Logged
gores95
Full Member
'06 Caldera Geneva
Re: Leveled cement.
Reply #13 on:
July 07, 2006, 06:18:05 am »
Make sure you post pics! Have fun in the new Vanguard!
Marc
Logged
cooltoy2000
Senior Member
Go Flames Go!!!
Re: Leveled cement.
Reply #14 on:
July 15, 2006, 02:57:55 am »
The location:
The close up:
The colours:
Logged
Re: Leveled cement.
Reply #14 on:
Print
Pages: [
1
2
« previous
next »
Original
Home
Buying Guide
Featured Products
Forums
Reviews
About
Contact
Copyright ©1998-2026, Whats The Best, Inc. All rights reserved. Site by
Take 42
