Author Topic: Bromine Spa Frog  (Read 5080 times)
cappykat
Bromine Spa Frog
« on: May 30, 2006, 08:41:35 pm »
Is anyone refilling their used bromine cartridges?  If so, what are you using?  I'm on my last cartridge and before I order again thought I might try refilling them.
2005 Marquis Epic
Bromine Spa Frog
Wolf_Racer
Re: Bromine Spa Frog
« Reply #1 on: May 30, 2006, 09:46:13 pm »
I am using the bromine tablets from home depot. It is exactly the same stuff, just in a tablet. After you get the spa frog open very easy to do. You might have to adjust the number a little different than with a new one, but it works great. I have been using it for a few months with no issues. Works just like the new ones and a lot cheaper.
Bonibelle
  • '05 Marquis Epic
« Reply #2 on: May 30, 2006, 10:34:19 pm »
Cappy, I had no luck getting my cartridges open. they were glued shut...but I understand that they are now making the bromine in cartridges that last a lot longer. Maybe you should check with your dealer first, it may be more economical to get the new cartridges then to try to open the old ones. I have the water thing down now, so I think I will just buy new cartridges rather than to learn how to adjust that frog! I am going to my dealer tomorrow and I will find out about the new ones ;)
DPS
  • The light was yellow, sir
« Reply #3 on: May 30, 2006, 10:52:38 pm »
There is a new bromine cartridge available from your Marquis dealer that costs about the same but has 30% more bromine in it.
« Reply #4 on: May 30, 2006, 11:20:19 pm »
This subject got discussed earlier and the people who make the frog tried to pressure people to stop taking about it. oddly enough, they stopped posting!  I'm just saying.
uncommonlytasty
  • I love my cheep spa
« Reply #5 on: May 31, 2006, 07:48:33 am »
The frog people also make a mineral filter insert.  Rather then messing with a used bromine cartridge, you could use a traditional bromine floater with the mineral filter insert.
cappykat
« Reply #6 on: May 31, 2006, 08:38:41 am »
Wmccall...yes, I remember well.  I just wanted to know who might be refilling and what they are using.  Not trying to "beat a dead horse".
2005 Marquis Epic
Bonibelle
  • '05 Marquis Epic
« Reply #7 on: May 31, 2006, 02:36:27 pm »
Cappy, I got the new cartridges, they are supposed to last a lot longer but just like DPS said, they cost the same.  They are packaged in green containers.
I am  finding that I am using much less bromine since I am running my tub in economy mode. It injects less bromine..So far (thankfully) so good. Have you switched your tub to economy yet?
« Reply #8 on: May 31, 2006, 04:38:50 pm »
No problem, I see no problem discussing it, I was just making light of their attempt at censorship.
cappykat
« Reply #9 on: May 31, 2006, 04:49:28 pm »
Boni, no I haven't but I will.  When we left to go to Jax with the family emergency I guess the bromine was empty so when we came back the water was slightly cloudy.  I shocked it pretty good and it's ok now.
« Last Edit: May 31, 2006, 04:53:11 pm by cappykat »
2005 Marquis Epic
Bonibelle
  • '05 Marquis Epic
« Reply #10 on: May 31, 2006, 04:52:37 pm »
Cappy, When my kid started doing that with his eyes, I got him new glasses...best check on that kitty!
cappykat
« Reply #11 on: May 31, 2006, 04:55:51 pm »
My "cappy" is almost human, but if he starts doing that we're off to the America's Funniest Videos!!
2005 Marquis Epic
NE-Phil
  • Marquis Reward '05
« Reply #12 on: May 31, 2006, 09:08:26 pm »
cappycat,
I have been refilling my cartridges since the beginning of the year and its been working well.
Is there a Leslie's Pool Supply around? I have been buying bromine tablets for refilling my frog cartridge from them.
By the way, it is the exact formulation with the exact percentage (96% bromine and 4% other ingredients. The type of bromine is 1-Bromo-3-Chloro-5,5-Dimethylhydantoin) as is found in the cartridges.
I checked before I bought. I love the fact I'm saving $$$.
Here's an earlier thread on this subject.
Phil
Not a mountain lake? Then it's still a chemical soup!
Bonibelle
  • '05 Marquis Epic
« Reply #13 on: May 31, 2006, 09:11:58 pm »
Phil, Hang on to those old cartridges because you can't get them apart anymore. I busted several trying to get the top off. They have glued them on.
NE-Phil
« Reply #14 on: June 01, 2006, 06:46:51 am »
Bonibelle,
That's what I've heard. I have two of them and that's more than enough for now. Maybe someone will figure out a cheap alternative.
So much for new and improved!  >:(
Phil
