Author Topic: Algie??  (Read 3326 times)
Bosmani
  • lifes to short to drink cheap wine
Algie??
« on: April 27, 2006, 08:43:50 am »
friend has an indoor pool with hot tub attached. The pool has a sand filter and the tub standard finned paper filter. He uses bromine tablets in both as well. He has black staining comming from the floor jets in the tub aand I feel it may be an algie? Had to rub off but will with a scrub. Any thoughts on cause or cures please?
Algie??
hottubdan
Re: Algie??
« Reply #1 on: April 27, 2006, 09:47:24 am »
Does he use an algaecide?
Bosmani
Re: Algie??
« Reply #2 on: April 27, 2006, 11:18:05 am »
Dont think so, The usual PH up and down, TA , and sanatiser.
Re: Algie??
« Reply #3 on: April 27, 2006, 11:29:28 am »
Yuk.
I don't know the ramifications of having the hot tub and pool exchning water, but
With my outdoor AGP, for algie, I use an algicide (the black aglicide, can't remember the name, but a dealer will know it). Scrub the sides, and for good measure, he could replace the sand in the filter.  ($30)
Clean the Hot tub filter and super chlorinate.
If this doens't do it,  I think he's looking at a complete water change out.
Bosmani
Re: Algie??
« Reply #4 on: April 27, 2006, 11:54:32 am »
Thank you
Micah
Re: Algie??
« Reply #5 on: April 27, 2006, 11:56:13 am »
We used to have problems with "Kobalt" on older gel-coat spaswhere black stuff would seep out of pours in the shell.  Only applies to older spas.  If so drain and clean with acid / water mixture (kind of like acid washing a pool) and a great addition to you chemicals to stop it from coming back is a product called "Kobalt Killer" from ARM products
Jacuzzi, Hot Springs and Caldera dealer in Los Angeles
Re: Algie??
« Reply #6 on: April 27, 2006, 03:07:51 pm »
 Yes! Kobalt Killer is the bomb on the 'black plague.'
I have been in the biz long enough to have done battle with this nemesis many times, but as mentioned, not on the newer tubs.
And never on a HotSpring, since they don't have fiberglas backing.
Re: Algie??
