Author Topic: Help!!  Alk off the charts  (Read 3725 times)
orlandoguy
  • all you need is tub
« on: February 08, 2006, 06:44:00 pm »
I just did a refill and made a big mistake.  I poured WAY too jmuch baking soda in and the alk is off the charts.  I have been adding ph/alk down all day and have added nearly a quart.  I knew there was a problem last night when I was itching like crazy.
I am wondering if it will straighten out or if I should just drain again?
I added almost half a small container of the baking soda!
bosco0633
  • Look into my eyes
Re: Help!!  Alk off the charts
« Reply #1 on: February 08, 2006, 06:46:44 pm »
if you use bromine, I would say leave it.  Bromine drops you alk level alot over a couple of weeks.  If not I would say drain it and refill
« Reply #2 on: February 08, 2006, 06:47:25 pm »
You could easily get into a chemical spiral adding one thing to compensate for too much of another and have your TSD levels way out of range.  Being in Orlando, I'd drain and refill.
orlandoguy
« Reply #3 on: February 08, 2006, 07:10:42 pm »
I think a drain and refill will be best.  Thanks, and chalk it up to experience.
I use bromine and just shocked, which normally drops the alk.  I will take another sample in tommorow.
« Last Edit: February 08, 2006, 07:16:02 pm by orlandoguy »
J._McD
« Reply #4 on: February 08, 2006, 11:04:53 pm »
How was your water before you drained it the first time?  Was it in bad shape and thus the reason you drained it? ???
« Reply #5 on: February 09, 2006, 10:35:40 am »
I agree.  I think it was said here in this forum (and I think many times we forget) "water is the cheapest chemical you can add to your tub."
« Reply #6 on: February 09, 2006, 11:00:57 am »
Chas, who doesn't pop in here near as much as he used to, (hint, hint), has been preaching that for as long as I've been hanging out here.
Probably longer.
orlandoguy
« Reply #7 on: February 09, 2006, 03:16:30 pm »
My water had been in the tub for 4 months and was what I call "stale".  It had the fizzing and other negative characteristics that say it's time to change.
With the Shop Vac and battery pump I bought from Spa Depot, water changes are done in a couple hours, so I guess I was just lazy.
After filling, I wanted to get the alk right then worry about the other levels.  I was absent minded and poured too much baking soda in and the alk and ph went off the charts.  I poured nearly a quart of ph/alk down in and shocked and boosted the bromine.
The end result was today all levels were perfect following a computer analysis.  I will do the alk up in a slower fashion in the future.
Chris_H
« Reply #8 on: February 09, 2006, 04:12:48 pm »
One gallon of Muriatic Acid should do the trick.
