Sign up
Log in
It's HOT...
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to our forum.
Home
Help
Search
Login
Register
Original
Out of Control Control Panel
« previous
next »
Print
Pages: [
1
Author
Topic: Out of Control Control Panel (Read 4455 times)
alwaysperky
Junior Member
Hail the flashlight king!
on:
January 24, 2006, 11:21:29 pm »
Calling all spa tech types.......
I was wondering if I could you guys to weigh in on my new issue? Tonight I discoverd my 5 month new spa's control pannel started acting possessed. Basically it's cycling through all the various settings. 1st is goes through the 4 filtration cycles, then it will say flash "fil" then "Circ", the switch to "economy" then back to regular time and temp. Pump controls, bubbles, and Lights controls still work.
Any ideas on the cause? Service Bulletins? Should I reboot?
Last Edit: January 24, 2006, 11:27:12 pm by alwaysperky
Logged
on:
Cola
Full Member
Time for bed kids
Re: Out of Control Control Panel
Reply #1 on:
January 25, 2006, 06:35:59 am »
Not sure here but I would reboot
Trip the GFI and wait a minute to reset
Later
Logged
Ultimate Member
Lead me not into temptation- I can find it myself!
Reply #2 on:
January 25, 2006, 08:21:29 am »
If rebooting doesn't work, and you don't get any other viable solution here, try posting your issue on Doc's board. There are several tech's who regularly post there, and offer pretty good advice for self diagnostics on this type of thing.
Logged
Mentor Level Member
Reply #3 on:
January 25, 2006, 11:12:30 am »
You can try rebooting but that probably won't fix anything and if it does you have to wonder if it's just temporary. It sounds like you have an issue with either your main control or the auxilliary control (assuming you have one). If you're worried about how long it takes to get the service out there you could try disconnecting the auxilliary control to see if that goes away. If it does, leave it like that until they arrive (you don't need the aux control and it's an easy swap out). If it is at the main control then you'll need to get service out there so monitor it daily to make sure you're staying at temp.
Logged
SerjicalStrike
Full Member
Reinstate Hank Williams!!
Reply #4 on:
January 25, 2006, 11:32:53 am »
It sounds like a main control panel problem. I am guessing it is a sundance. The auxillary control only controls the motors (pre aquaterrace waterfall) or the aquaterrace lights.
Logged
alwaysperky
Junior Member
Reply #5 on:
January 25, 2006, 09:24:02 pm »
Yes, it's my 2005 Optima. It has the aux control pannel, which is working perfectly, it controls lights only.
I've contacted dealer via email last night, and phone today. So far I've not had any response.
Tonight the "cycling" through issue has stopped. Looks like pannel is working normally in that I can view time and temp, and adjust the temp, but cannot confirm or adjust the filtration cycles with either the select or cycle buttons because they now appear dead.
Could you remind me which site is Docs?
Logged
Ultimate Member
Reply #6 on:
January 26, 2006, 07:48:52 am »
Try
www.rhtubs.com
, and click to the spa forum.
Sounds like you did all you could by re-booting. If you're still having issues, it should be covered under your warranty, so I wouldn't mess around with it too much more. Hopefully you can get the service people out there. Let us know what the outcome is.
GL2U.
Logged
alwaysperky
Junior Member
Reply #7 on:
January 28, 2006, 12:12:46 pm »
Thanks for the advise.
Just wanted share with you my results.
I emailed them on Tuesday, called them on Wednesday, they said they were on it, called them again on Thursday........no record of my call or email?
I asked them to call my cell phone to set up a service call. They called on wife's number on Friday, said they'd be out between 10 and 1 Saturday.
I took the kid to the T-Wolves camp until 10 and when I got home they'd already been out and replace the control pannel.
Now if I could just get rid of the Baqua tar.
Thanks again.
AP
Logged
Cola
Full Member
Time for bed kids
Reply #8 on:
January 28, 2006, 03:28:55 pm »
Check your Flux Capacitor
Here's how
Set the date for 1985
Set the temp for 88 degrees
Climb in and turn the pumps to high
Close your eyes
If the problem doesn't disappear, you have a faulty Flux Capacitor
Doc can help you with getting it replaced.
Good luck
Logged
alwaysperky
Junior Member
Reply #9 on:
January 28, 2006, 07:35:40 pm »
Cola!
You failed to explain how I could possibly generate the 1.21 gigawatts of power needed in order to activate the flux capacitor. Anyone knows you need 1.21.
???The fact that you left that part out ..................I guess I will I'll rely on the experts from this point forward.
Pepsi or Coke?
Logged
Cola
Full Member
Time for bed kids
Reply #10 on:
January 28, 2006, 11:49:08 pm »
Yes, I fell asleep during that part last night
Logged
Reply #10 on:
Print
Pages: [
1
« previous
next »
Original
Home
Buying Guide
Featured Products
Forums
Reviews
About
Contact
Copyright ©1998-2026, Whats The Best, Inc. All rights reserved. Site by
Take 42
