Author Topic: Custom-cut thermal blanket  (Read 2195 times)
leaky
  • Don't ask about the nickname...
« on: November 23, 2005, 11:20:54 am »
All,
I promised these shots a while back, but finally got to posting them.  I custom-cut this thermal blanket to a VERY close fit; I just fling it over the top of the cover when jumping in.  After a couple of months, I don't know if it really helps the energy consumption or not, but it hasn't been much of a hassle to use, and I do think it will save some wear and tear on the inside of the cover.  For those of you in the cold climates, it might be a good investment.   For others, just having Tammy over every night would generate plenty of heat.... ;)
Bonibelle
  • '05 Marquis Epic
Re: Custom-cut thermal blanket
« Reply #1 on: November 23, 2005, 11:49:23 am »
Just wondering, is that a solar pool cover? I think it is a great idea to protect your cover and it can't hurt on the energy conservation either!
leaky
« Reply #2 on: November 23, 2005, 12:01:09 pm »
It's not a pool cover per se, as they're giant and expensive.  It's the same thing, only in a small size and under $30.
