Author Topic: Poll: How do you test your water?  (Read 9790 times)
Re: Poll: How do you test your water?
« Reply #15 on: November 08, 2005, 06:15:44 pm »
I use multiple choice, I think it is more fair for the water than fill in the blank.
HTH Test kit, $15 at Walmart
tonyp
  • Soaking in a HS Envoy!
« Reply #16 on: November 08, 2005, 07:41:19 pm »
My water finds multiple choice too hard.  So I soften it up with a True/False test and occasionally shock it with a pop quiz ;D
Strips and HTM from WalMart
« Last Edit: November 08, 2005, 07:42:14 pm by tonyp »
stl-rex
  • Arctic Tundra Owner
« Reply #17 on: November 08, 2005, 08:30:48 pm »
Checkit pH Meter.  Strips for everything else.  I hate picking among the colors on the strips for pH.  Everything else is usually a pretty clear cut indication.
drober30
  • Loving my HS Vanguard!
« Reply #18 on: November 08, 2005, 08:35:04 pm »
Taylor test kit.  Strips for free chlorine only.  I find test strips for everything else totally unreliable too!
nicker
« Reply #19 on: November 09, 2005, 08:17:27 am »
test strips here for my quick tests and once a week I use my taylor kit.
For those that use the test stips that also test hardness...what brand are they?  And do you find them easy to read?  I have separete strips for hardness and they are hard to read.  Id like to get the stips that test, Clorine, Alk, PH and hardness all in one.
« Reply #20 on: November 09, 2005, 09:22:33 am »
I picked up a spa test kit the other day, and wow, I mean
what is this stuff?
Alexander the Great is to Persians as Dichlor is to _______?
I'm going back to the regular  old dopey  test strips.   ???
« Last Edit: November 09, 2005, 09:31:25 am by drewstar »
grahamtasia
  • Life is not short!
« Reply #21 on: November 09, 2005, 12:06:02 pm »
Test Strips work well
Bodyaches
« Reply #22 on: November 09, 2005, 12:09:14 pm »
Old fashioned way.
Double tube test for clorine and PH.
SemperFi   Dick
ssbraun
  • '05 Maxxus
« Reply #23 on: November 09, 2005, 12:15:13 pm »
Old fashioned way.
SemperFi   Dick
Unless I'm mistaken, this method gives a total chlorine result rather than free chlorine (as in the kind that can do the killin')  Please correct me if I'm wrong!
drprwnap
« Reply #24 on: November 09, 2005, 12:20:23 pm »
Thanks for all the replies.  I'm finding the test strips hard to read.  Thinking about getting something different but haven't decided yet. Might try a pH meter....
drprwnap  8)
Lovin' Spatopia in my Epic!
« Reply #25 on: November 09, 2005, 12:23:20 pm »
The older test kits (OTO) would check only TC, however it's my understanding that the newer kits that use DPD, check for Free chlorine.
« Last Edit: November 09, 2005, 12:24:56 pm by drewstar »
Backpains
  • proud owner of a Coleman 461
« Reply #26 on: November 10, 2005, 04:20:40 pm »
Test strips..check once a day usually in the am when hubby and I go out for our first soak at 5:am (btw...this is the most COLDEST darn winter I think I've ever felt around these parts!!!! Who was the one who talked me into skinny dipping????? Who was the IDIOT who said "au Natural" is best????)
TattedVenus
« Reply #27 on: November 10, 2005, 06:17:04 pm »
Bioguard 1200V Test Kit, and test Calcium at the store once a month
TrikkeAddict
  • 2005 Sundance Cameo
« Reply #28 on: November 10, 2005, 06:39:35 pm »
Taylor test kit
Daveflave
  • Go WSU Cougs!
« Reply #29 on: November 10, 2005, 06:50:15 pm »
Didn't like the test strips so I bought a Cool Pooltester.  It's basically a colorimeter and costs about $100.  Very accurate.
