Author Topic: Bullfrog Spas  (Read 11533 times)
poolboy34
Re: Bullfrog Spas
« Reply #15 on: April 18, 2005, 11:30:22 pm »
actually many auto dealerships require a copy of a valid driver's license (duh, i would hope so) which they take untill you return from the test drive, and also many require a C/C # before test driving.
Re: Bullfrog Spas
zzaphod42
Re: Bullfrog Spas
« Reply #16 on: April 19, 2005, 10:25:03 am »
What's next, charging admission to the store?
Can you say Costco? :o
JcDenton
  • Be Cool or be cast out
Re: Bullfrog Spas
« Reply #17 on: April 19, 2005, 11:33:49 am »
Touche.
How do you know how much you don't know?
Re: Bullfrog Spas
« Reply #18 on: April 19, 2005, 01:31:55 pm »
But that admission doesn't get you a wet test.
mike-n-bon
Re: Bullfrog Spas
« Reply #19 on: April 19, 2005, 02:39:44 pm »
What I read "con" about Bullfrog, is that unless you change the packs often, the water will go stagnant behind the seats.  Also, in my area, that are outrageously overpriced -- start at $10,000 with no bells or whistles.
nrkissed
Re: Bullfrog Spas
« Reply #20 on: April 19, 2005, 03:29:44 pm »
Wow, thats pretty steep considering they started under $7000 here.  And thats for the 451 model not the stripped down Tadpole line.
As for the stagnant water issue, I found that to be a old issue still being used as a scare tactic by most other dealers.  Almost all of the current Jetpack options have a circulation hose built into them now.  Be sure to check your top Jetpack choices to verify they do have the hose as I cannot remember which ones did not.
How well the circulation hose works I cannot say, but there are several satisfied owners locally that have stated the issue is pretty much old news now.  (All supplied by the dealer)
Re: Bullfrog Spas
