Author Topic: how often are you supposed to shock?  (Read 2914 times)
hair
  • artesian gives lust, jealousy gives regret
« on: March 26, 2005, 10:14:59 pm »
hi, using chlorine sanitizer, someone told me i should shock after each use. is this true? even if i use every day, i also heard you should shock once or twice a week depending on time spent in spa.  what's correct answer?
BadBack
  • In a state of Euphoria!
Re: how often are you supposed to shock?
« Reply #1 on: March 26, 2005, 11:39:08 pm »
My dealer also said two or three times a week, and I am wondering the same thing.
JTJ23BA
  • I love my HotSpring!!!
« Reply #2 on: March 27, 2005, 12:33:39 pm »
My Spaguard dealer says to shock once a week.  My shock is 56% dichlor.  After each use I add a tsp of 97% dichlor.
« Reply #3 on: March 27, 2005, 04:24:07 pm »
Shock weekly. Not weakly but weekly! ;D
Bill_Stevenson
  • Hot Spring Envoy
« Reply #4 on: March 27, 2005, 05:27:58 pm »
Steve gave you the right answer, shock once per week.  If you are using dichlor, you should use approximately 6 or 7 times the amount that you use after each soak.  So for example, if 1 teaspoon after soak gives you 3-5 ppm 15 minutes after adding it, then for shock you should add approximately 2 tablespoons plus 1 teaspoon.  This may be somewhat conservative, but it is safe.
Regards,
Bill
