Author Topic: Just turned hot tub on and yuk  (Read 2626 times)
KW_in_PA
« on: March 12, 2005, 02:59:40 pm »
I just finished wiring my new Sundance hot tub and turned it on.  I bunch of black slime pieces are floating all around.  What the heck is it and what should I do?  Help
HotTubMan
  • My 2.1 cents, eh
Re: Just turned hot tub on and yuk
« Reply #1 on: March 12, 2005, 03:10:53 pm »
Shock the heck out of it. Circulate the water for an hour. Drain and refill.
hottubber
  • Hottubbing under the stars...PRICELE SS
« Reply #2 on: March 12, 2005, 03:56:56 pm »
kw,
Put at least 3 ounces of DiChlor shock in the spa and let it run for about one hour. Turn the heat all of the way down, you don't want to heat water that you are going to dump.
DO NOT put anything else in the water. Drain the spa tonight, wipe it down, remove any of the black pieces that may be sitting in the spa and hose down the filter.
Refill tonight and be ready to use in the AM.
Good luck, hottubber... ;D
PS. I believe the particles that are coming out of the jets are from the stagnant water from testing at the factory. It is a sort of algae. Non harmful, though.
« Last Edit: March 12, 2005, 03:57:39 pm by hottubber »
Lori
« Reply #3 on: March 12, 2005, 08:30:16 pm »
Oh wow!   :'(  Sorry!
You'll get good advice here!
