Author Topic: zip code 46311 Marquis where r u?  (Read 8347 times)
busdude
« on: February 18, 2005, 10:28:06 pm »
subject pretty much says it all
Re: zip code 46311 Marquis where r u?
« Reply #1 on: February 18, 2005, 11:25:52 pm »
What did you find out when you used the dealer locator on their website?
stuart
« Reply #2 on: February 18, 2005, 11:31:32 pm »
Heck! I'll set you up with a spa and get you a service in your area! I have an email into the factory for you...
zzaphod42
« Reply #3 on: February 19, 2005, 08:27:14 am »
This is the closest Beachcomber dealer if that is any help:
DesRochers Backyard Pools
Address:
550 DAVY LN
Shorewood IL 60435
Tel:  (815) 730-8548
Fax: (815) 730-8551
It might be worth checking out.
« Last Edit: February 19, 2005, 11:17:14 am by zzaphod42 »
poolboy34
« Reply #4 on: February 19, 2005, 09:54:01 am »
Here are the closest D-1 and Caldera dealer http://www.aspools.com/
« Reply #5 on: February 19, 2005, 10:23:52 am »
I'll throw in the nearest Dynasty Dealer (17 miles)
http://fimstores.com/
spaguyohio
« Reply #6 on: February 19, 2005, 10:41:01 am »
Ok, Ill join the bandwagon, heres the nearest Master Spas dealer:
MIDWEST SPA DISTRIBUTORS INC.
Address 8601 Pyott Road Bldg A
Lake in the Hills, IL, 60014
Phone 815-356-7727
Email weskey@aol.com
Distance Approx. 66.4 Miles
zzaphod42
« Reply #7 on: February 19, 2005, 11:19:25 am »
Hopefully one of the brands mentioned will suit your needs!
busdude
How far would you drive to wet test & buy
« Reply #8 on: February 19, 2005, 12:44:22 pm »
Thank you all. I'm going to go to Dynasty and wet test next week (Alsip). I don't know where the other towns are but I will do map quest and find them.
The Marquis website tells me the nearest dealer is more than 75 miles away and I need to call the Marquis 800 number which is inconveniently open the same time I'm at work and just haven't had a chance.
Lori
« Reply #9 on: February 19, 2005, 06:34:39 pm »
Busdude,
Stuart will hook you up!  No worries, just be patient!
Enjoy your wet test!
Ruby
  • Marquis Epic
« Reply #10 on: February 19, 2005, 07:03:52 pm »
I agree with Lori!  Marquis is great.  I would definatly find the time to check them out and wet test them.
Minnesota Consumer
Been soaking since 7/2004
stuart
« Reply #11 on: February 21, 2005, 07:33:09 pm »
Buds,
I'm having someone with Marquis contact you here through a PM or answer on this topic as I'm leaving for Mexico. I will check while I'm there to make sure they did....
BIG_PAPA
« Reply #12 on: February 21, 2005, 08:54:18 pm »
I would definately be patient with Marquis.I think it is worth the wait.They make an awsome tub!!
« Reply #13 on: February 23, 2005, 01:50:30 pm »
Definitely call their 800 number.  The last time I checked it gave me a dealer in Michigan that was 250 miles away, then I heard from a Beachcomber owner on this forum and he bought from a Ohio dealer only 100 from me. doublechecked and today is shows on 45 miles away.  I hope they come to the State Fair, I've never seen a Beachcomber in person.
« Last Edit: February 23, 2005, 01:52:32 pm by wmccall »
« Reply #14 on: February 23, 2005, 06:03:14 pm »
They're just crap anyway Bill... ;)
Just teasing all my Beachcomber friends out there! ;D
Check out their new 538 model...I sat in it last week when I went into the store I use to work for here. Quite unique.
