Author Topic: wiring for HS prodigy  (Read 2905 times)
thunder57
« on: October 25, 2004, 02:01:16 pm »
Well after many wet tests we have decided to get a HS Prodigy. It will be delivered this weekend. I have the electrician coming over soon. One of the reasons we picked the Prodigy is to be able to run on 115V. What should I make sure he does?
Thanks.
PPOL
Re: wiring for HS prodigy
« Reply #1 on: October 25, 2004, 04:03:42 pm »
Run a separate 20Amp line to the spa location and place a plug a good safe distance from the spa (about 5' is minimum)
Happy Tubbing,
Neil O'Donovan
Phoenix Park Outdoor Living
Wilmington, NC
« Reply #2 on: October 25, 2004, 04:29:50 pm »
The Prodigy comes with a 15' long cord, but you should only count on being able to use about 12' of it.
There is a very special plug and cover combo that comes with your spa. PN 34986.  Your dealer should give it to you now so you can have it installed by your electrician - that way it's ready for 'plug and play.'
Allow at least 12 hours for heat up, BTW.
You'll enjoy this tub. I sell a pack of 'em - and they work well.
