Author Topic: Twilight 8.25 very loud diverter valve  (Read 7919 times)
hobble23
« on: November 22, 2019, 01:14:20 am »
Hello, just got a new master twilight 8.25.  I find the diverter valve for the master blasters and 2 back chairs quite loud. Is this expected? It really annoys me. The other valve is not loud at all.
Re: Twilight 8.25 very loud diverter valve
« Reply #1 on: November 22, 2019, 08:17:17 am »
Loud diverters are common. Plumbing engineering is expensive. Some companies don't spend as much money on it. Does it help to fully turn it one direction or the other? Not in between.
hobble23
« Reply #2 on: November 22, 2019, 10:41:48 am »
The sound changes in pitch when going from one to the other but the loudness is about the same.  Anyone else with this tub notice this?  I have a great dealer support but I like to avoid calling them and complaining if it's common among all the twilight 8 tubs.
BullFrogSpasMN
« Reply #3 on: November 22, 2019, 12:32:23 pm »
common among brands using old school diveter knobs (typically the first thing to fail on a spa) you can attempt to remove the entire valve and 're-seat' it and ensure none of the O-Rings are pinched or damaged causing an air leak which is causing the noise
swilly1000
« Reply #4 on: November 22, 2019, 05:41:05 pm »
I have the same hot tub (which I flippin' love BTW) and some times the diverter valve that controls the big foot jets can be noisy.
I find that turning off the pump before turning the valve helps because you can turn it all the way easier with the pump off.
You should be turning off the pump anyway before turning the valve as it's hard on the valve when turning it with all that water flowing.
I actually broke my other diverter valve last winter forcing it with the pump on.  It was one of the coldest days of winter when it happened so the plastic part cracked at that temp and with that force of water on it.  Incidentally my dealer was out to my house fixing it under warranty early Saturday morning after being called Friday evening.  Pretty impressive
« Last Edit: November 25, 2019, 05:17:09 am by swilly1000 »
hobble23
« Reply #5 on: November 22, 2019, 06:24:37 pm »
Yeh the tub and is awesome in any case.  I will take it apart I think and take a look and see what I see I think as I soak this weekend.  I’m certain somehow this can be improved.
BullFrogSpasMN
« Reply #6 on: November 22, 2019, 06:55:07 pm »
it can easily be improved if manufacturers would spend more than $8 cost on cheap plastic parts that 'move' frequently under pressure like a diverter and ironically it has nothing to do with the cost of the spa...I've seen better divterters on $6,000 tubs than I have on $14,000 tubs
hobble23
« Reply #7 on: November 22, 2019, 07:34:19 pm »
So can I purchase one of these better diverted and install it in place?
« Reply #8 on: November 23, 2019, 08:12:43 am »
I dout your warranty will support replacing a diverter that is working as intended. But you could replace it. Plumbing engineering has a lot more to it than just replacing a diverter valve.
Cavitation is common in plumbing. There are several components that have an effect on it.
I certainly could give you a solution but you won't like it. And neither will swilly.
swilly1000
« Reply #9 on: November 23, 2019, 02:48:48 pm »
No I won't!  Lol
hobble23
« Reply #10 on: November 24, 2019, 04:30:45 pm »
Actually it seems not turning the diverter when the pump is on has resolved it.
swilly1000
« Reply #11 on: November 25, 2019, 05:16:13 am »
There you go!
« Reply #12 on: November 25, 2019, 11:00:51 am »
That's the standard backup plan when you have a poor quality diverter but its better than any attempt to remove/replace it.
