Author Topic: How long do you run your filtration system daily?  (Read 2568 times)
sjde
« on: June 06, 2019, 07:44:13 pm »
I have mine set for 2 hours twice a day which is more than the default, but am wondering if longer is better?
Re: How long do you run your filtration system daily?
« Reply #1 on: June 07, 2019, 07:09:35 am »
Depends on how much you use the tub. Is 4 hours a day enough to keep your water clean?
The Wizard of Spas
« Reply #2 on: June 07, 2019, 09:32:44 am »
While your tub might be set for a total of 4 hours - you have to add whatever time the tub is kicked into heating mode to maintain your temp.  Thus - throughout the day your tub might be jumping into filter mode to catch back up to the desired temperature.
