Author Topic: Any do's and dont's when filling the tub!  (Read 5614 times)
sobe
  • Sundance optima owner
« on: August 31, 2004, 09:38:34 am »
The electrician should be wiring the optima today so if everything goes as planned, I should be soaking by midnight.
Looking for advice on filling the tub.
windsurfdog
Re: Any do's and dont's when filling the tub!
« Reply #1 on: August 31, 2004, 09:42:31 am »
Many manufacturers suggest filling through the filter compartment.  Check your owner's manual and follow it.  Congrats and good luck!
bethshar
« Reply #2 on: August 31, 2004, 11:05:47 am »
Sobe -
Once your tub is warm enough - get in a soak before you put the chemicals in.  It's hot today, so it may be great to go in at 85-90 degrees.  This way you won't have to wait so long!  Then you can put your shock in and soak again first thing in the morning.
Just curious - what chems is B&B suggesting you use.?
doodoo
« Reply #3 on: August 31, 2004, 11:08:01 am »
Recommendation for the manufacturer is to fill through the filter compartment. When I aske my dealer he shrugged and said 'toss the hose in' as long as you fill it. As soon as it was full I turned it on and it worked beautifully.
I remeber not that long ago though there was a post that described a situation where a jet was not working maybe due to an blockage of sometype which may have been caused by not filling from the filter area.
So........you decide! But hey as long as it is filled and working, right!  ;) :D
windsurfdog
« Reply #4 on: August 31, 2004, 11:12:17 am »
Try using 2 hoses, 1 for the filter compartment and one in the tub.  Worked for me last time....
tony
  • 2002 Optima
« Reply #5 on: August 31, 2004, 11:42:22 am »
Fill through the filter compartment.  Even better, put the hose right into the suction pipe on the pleated filter side.  Do not fill with the hose on full to avoid an air lock.
« Reply #6 on: August 31, 2004, 11:43:14 am »
Do: Set a timer.
Don't: Let the spa overfill cause something got your attention and ... Not that I've ever done that!
tony
  • 2002 Optima
« Reply #7 on: August 31, 2004, 11:46:11 am »
That just happened to me last week.  I thoght I had shut the water off and had the cover on.  The next thing I know, water pouring out on all sides.
Spa_Tech
  • Independent Spa technician
« Reply #8 on: August 31, 2004, 11:47:14 am »
Yeah t.u.o., a spa professional has never ever allowed a spa to fill to overflowing and flooded a showroom floor... ever... ;D
doodoo
« Reply #9 on: August 31, 2004, 12:20:50 pm »
I'd pay a few $$ to see that. LOL! ::)
« Reply #10 on: August 31, 2004, 12:27:20 pm »
That works for me, 30 minutes to fill that way. It wasn't intentional, but I put my spa halfway between my two outdoor faucets.
huh?
  • "42"
« Reply #11 on: August 31, 2004, 01:49:33 pm »
We did that here.  We used to have a bank in the same building...the bank managers office was just on the other side of the wall.  When we overfilled it flooded his office and ruined a ton of paperwork he had on the floor.  The just moved their office a month ago.  And we flooded it two years ago.  He would still not talk to us.lol
huh?
  • "42"
« Reply #12 on: August 31, 2004, 01:52:45 pm »
Sobe -
I wouldn't recommend doing this.  Some Manufacturers will do a diagnostic fill in the manuf. process.  Not all the time is this water drained out completely.  The water will sit in the dark/damp pipes and breed all sorts of fun stuff.  Can we say Psuedomonia's.  I wouldn't risk it.  Wait till the chlorine does its job.
« Reply #13 on: August 31, 2004, 03:00:15 pm »
"Any do's and dont's when filling the tub"
DON'T fill it with jello shots
DON'T try to use your neighbors hose wihtout asking
DON'T  watch porn movies on the built in TV if it faces your neighbor kids windows.
DON'T play rap music on the stereo while using.
huh?
  • "42"
« Reply #14 on: August 31, 2004, 03:12:55 pm »
I think there are a couple of OTHER reasons why you wouldn't want to do this... :o
