Author Topic: No power to circulation pump  (Read 3012 times)
Pat2017
« on: November 26, 2017, 04:39:59 pm »
I have a 2003 Sundance Capri with circulation pump problems. Couldnt get the circ pump to work so I ordered a new one ($230). Cant get the new one to work either! Discovered I have no power at the pump connections. Replaced all fuses on the control board, but still get no power.
Any ideas?
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: No power to circulation pump
« Reply #1 on: November 28, 2017, 10:48:54 am »
More than likely you have a bad relay.  Is your circulation pump wired with both the white and black wire right next to each other, or is the black wire hooked up to a relay and the white wire connected to the terminal block?
JacuzziJack
« Reply #2 on: November 30, 2017, 01:49:27 pm »
Yeah, there's a bunch of youtube videos that address board relays and no pump operation. Maybe you can find one that'll help..
