Author Topic: Previously winterized hot tub had water in it  (Read 1955 times)
hottubquestion
« on: July 02, 2017, 02:23:28 pm »
Hello everyone,
I had a spa service winterize my hot tub two years ago. The technician said that the winterization would last for a few years.
When I took the tarp and cover off today the hot tub was 1/3 full of water and nastiness. I watched the technician winterize it. He cleared out all of the pipes and then added anti-freeze to them.
However, I am a bit worried after seeing so much water in there. I currently drained the water I found in the hot tub and I was wondering if there was anything else I should do before cleaning, filling, and turning it back on?
Thanks for the help!
BullFrogSpasMN
Re: Previously winterized hot tub had water in it
« Reply #1 on: July 02, 2017, 03:32:12 pm »
you can do a simple visual inspection of the equipment compartment and note if anything is cracked/split/broken/etc....If everything looks normal all you can really do at that point is fill it up/power it up and basically just see what happens.  Good Luck!
