Author Topic: Loud sucking sound from filter  (Read 5874 times)
Starman
« on: February 05, 2017, 07:41:59 am »
I have a new Maax spa model 781. There is a vortex in the filter area and it has a round pre-filter . Occasionally there is a loud sucking sound.
Is this normal?
thanks
Re: Loud sucking sound from filter
« Reply #1 on: February 05, 2017, 01:41:41 pm »
 Yes, sometimes worse with low water level.  Some 200 series Jacuzzi's would do it as well, I usually suggested removing the skimmer that bobs up and down if it's annoying when you are in the spa.
Starman
« Reply #2 on: February 05, 2017, 03:39:12 pm »
No bobbing skimmer here only the weir door ,I could remove the prefilter
The Wizard of Spas
« Reply #3 on: February 06, 2017, 07:13:54 pm »
Keep water level higher and problem likely goes away.  Weir door removal, as noted, reduces/eliminates it too.
