Author Topic: Oxy-Spa  (Read 5404 times)
39lasalle
Oxy-Spa
« on: November 17, 2016, 05:04:06 pm »
I just started to use this last week and started itching like like crazy a day later....is any one allergic to this stuff?
Any thing to substitute?
39
Oxy-Spa
tmaestas95
Re: Oxy-Spa
« Reply #1 on: November 17, 2016, 06:02:20 pm »
You could try a different brand of MPS but I can't imagine there's all that much difference between them.  If it's the MPS itself you seem to be sensitive to then you can stick to just chlorine for both sanitizing and shock.
Re: Oxy-Spa
« Reply #2 on: November 17, 2016, 09:31:18 pm »
It is common to be reactive to MPS. A different brand won't help. Can you get by without it? Are you bromine or chlorine? Or other   :-[
39lasalle
Re: Oxy-Spa
« Reply #3 on: November 18, 2016, 08:44:56 am »
We are using Dichlor.....so i guess we dont have to use...
Just treat with dichlor after each use and shock once a week?
39
hottubdan
Re: Oxy-Spa
« Reply #4 on: November 18, 2016, 10:24:44 am »
That will work.
Re: Oxy-Spa
« Reply #5 on: November 18, 2016, 04:02:12 pm »
39
Try not to let the CY level get to high. Switch to straight unscented bleach after a few weeks.
MarKee
Re: Oxy-Spa
« Reply #6 on: November 18, 2016, 06:00:39 pm »
A lot of times people make the mistake of getting in the tub right after shocking the spa.  You always want to shock after you use the hot tub, and don't use it for at least 2-3 hours after shocking.  Also very important to leave the cover off when shocking, and don't over shock it.
Re: Oxy-Spa
