Author Topic: Delete  (Read 4053 times)
Edwin46
Delete
« on: March 18, 2016, 01:53:11 am »
Delete
« Last Edit: March 20, 2016, 04:03:38 am by Edwin46 »
Delete
Re: Caldera Frog capsule
« Reply #1 on: March 18, 2016, 06:49:26 pm »
The Frog system uses different minerals more tailored to Bromine. The Nature 2 Mineral system is more tailored to dichlor.
Hottubguy
« Reply #2 on: March 18, 2016, 09:41:39 pm »
Frog just came out the @ease program that you can get with dichlor through you're local dealer
Edwin46
« Reply #3 on: March 19, 2016, 03:28:35 am »
Delete
« Last Edit: March 20, 2016, 04:03:55 am by Edwin46 »
« Reply #4 on: March 19, 2016, 07:07:15 am »
I have The Caldera kuai 3 per
and i use also a mineral frog capsule , not The bromine that is forbidden in The netherlands.
but is the mineral frog NOT recommended?????
Why?
I,m using dichloor bleach method.
Your using a frog capsule (see above) Your not using bromine cause it's forbidden in the Netherlands (see above) But is the mineral frog NOT recommended????? (see above) Your using dichlor bleach (see above) Now read my answer.
Dr. Spa™ Ret.
« Reply #5 on: March 19, 2016, 10:10:00 am »
You're question is NOT clear.
Are you asking if the Frog is NOT recommended to be used with chlorine? Are you asking if the frog is not recommended to be used at all?  Are you asking if the frog is not recommended to be used in the netherlands? Are you asking if the Frog is NOT recommended to be used in Caldera Spas?
Re: Delete
« Reply #6 on: March 20, 2016, 12:17:38 pm »
What happened there Doc?
JustAnotherNewbie
Re: Delete
« Reply #7 on: March 20, 2016, 04:37:45 pm »
What we had there, is a failure to communicate.  ;D
Dr. Spa™ Ret.
Re: Delete
« Reply #8 on: March 20, 2016, 05:10:48 pm »
Lost in translation?
Re: Delete
« Reply #9 on: March 20, 2016, 08:00:58 pm »
Sometimes logic makes people mad.
Re: Delete
