Author Topic: Marquis Spirit 2014 water feature issue  (Read 5898 times)
Brian3248484
« on: November 08, 2015, 07:09:41 pm »
Hello everyone, I was wondering if anyone knew what could be wrong with my water feature on my hot tub.  Whenever the jets are on I can no longer turn off the water feature on the Marquis and the knob just lets it go down about halfway when turned all the way off.  It's not really a big deal but it's only about three months since we've gotten it.
Hottubguy
Re: Marquis Spirit 2014 water feature issue
« Reply #1 on: November 08, 2015, 10:37:17 pm »
Put the tub on quiet soak to shut everything down then pop the top off the wf valve unthread and clean the insides of the valve off. There is probably something in there that's blocking it from shutting all the way. Will take you less then a minute to fix
MarKee
« Reply #2 on: November 09, 2015, 01:25:25 am »
You need a new waterfall/neck jet valve insert. You can swap it yourself in 15 seconds. Should be a $5 part at your local dealer.
Brian3248484
« Reply #3 on: November 11, 2015, 10:41:48 am »
Thank you guys for the advice.
