Author Topic: Getting ready to pour a concrete pad  (Read 3913 times)
Thedoc
« on: September 24, 2015, 11:02:19 pm »
I am getting ready to pour a 14x24 concrete pad for a future hot tub.... have not made a decision on which one yet...I will be reinforcing with wire mesh will that be enough or should I add rebar where the tub will sit.. concrete will be run from 4-6 inches deep.
Sam
Re: Getting ready to pour a concrete pad
« Reply #1 on: September 25, 2015, 03:35:43 pm »
It's probably fine with 4 to 6" and mesh, but I personally prefer adding rebar.
Dr. Spa™ Ret.
« Reply #2 on: September 25, 2015, 06:31:07 pm »
Technically, if it's less than 6" you shouldn't use rebar as it will actually cause cracking along the rebar.
av8r
« Reply #3 on: September 25, 2015, 08:48:41 pm »
Will the concrete company offer adding fiber to the mix for strength?  We've had great results with that for over a decade on monolithic slabs.
Thedoc
« Reply #4 on: September 26, 2015, 10:57:29 pm »
Thanks for the replies I have been out of town and just got back.....they will add fiber I am pretty sure so I guess I will go with the 10ga. mesh
av8r
« Reply #5 on: September 27, 2015, 01:29:42 pm »
Probably overkill for this as the fiber will give more strength than mesh will and none of the issues with corrosion, etc., but good luck whatever you decide.
