Author Topic: GFCI distance  (Read 5852 times)
Bigralphy
GFCI distance
« on: April 24, 2015, 09:47:07 pm »
Hi folks,
New tub coming in a couple weeks but I have a question. In my area code states the gfci must be 3 meters from the tub.  How far from the tub can the gfci be to not have false tripping?  I have read that if the distance is too far it can cause false tripping but what is considered too far?
Any help is appreciated and if some owners could mention how far their gfci panels are from the turn that would help as well
GFCI distance
Re: GFCI distance
« Reply #1 on: April 24, 2015, 09:51:53 pm »
 I don't think it matters how far it is away for false tripping.  It matters what the code is on what's the farthest it can be away.   In the states I believe it's not greater than 25 ft away and (insight of the spa kinda grey area)  So where you are it might be different need to confirm what your code is.
Re: GFCI distance
« Reply #2 on: April 24, 2015, 09:54:20 pm »
Isn't it no more than 25 and within sight. But no closer than 5-6'. You shouldn't be able to reach it from the tub.
Re: GFCI distance
« Reply #3 on: April 24, 2015, 10:07:18 pm »
 Yes, but 25' within sight can be determined by the inspector.  In other words if he is a -ick or not.   ;)  I have had some say it's fine and I have seen some say no way.  Really depends on how it's ran.
Bigralphy
Re: GFCI distance
« Reply #4 on: April 24, 2015, 11:59:12 pm »
CEC states minimum 3 meters from spa but it does not need to be in sight and there is no maximum distance.  At least from what I can read in section 68 of the code
Thanks for the input guys
mai95
Re: GFCI distance
« Reply #5 on: April 27, 2015, 04:39:31 pm »
Not sure about GFCI, but my breaker box had to be located at least 5 feet away from the spa. And any fan above the spa had to be at least 12 feet away (even outdoor fans). For Lights it had to be at least 7 feet above the waterline.
Dr. Spa™ Ret.
Re: GFCI distance
« Reply #6 on: April 27, 2015, 07:43:14 pm »
The first 2 w's in www stand for "world wide". Bigralphy is NOT in the United States and therefore is not governed by US building codes, or laws.
Re: GFCI distance
