Author Topic: Marquis Euphoria Cloudy Water HELP Please  (Read 4742 times)
treviso
« on: July 08, 2004, 02:46:43 pm »
Hi,
I have been having a very difficult time with the chemistry in my Marquis Euphoria having very cloudy water.  It is a new tub with the new Frog Bromine system.  When I add the clarifying solution, I end up getting lots of foam...so I add the anti-foam solution and it stays cloudy.  The bromine levels tend to look low most of the time even when I open up the bromine cartridge all the way on 6.  The dealer tells me that my PH/alkaline is too high, but most of the time it registers too low.  The bromine levels tend to be low.  He told me to continue to shock the tub after every usage...I am totally confused and disappointed that this is so difficult to get a handle on.  Please, I need help  FAST.  I thank you in advance.
Robert
treviso
Re: Marquis Euphoria Cloudy Water HELP Please
« Reply #1 on: July 10, 2004, 12:32:27 pm »
No one out there has any advice for me?
IonHeaven
« Reply #2 on: July 10, 2004, 01:27:31 pm »
I'm going to wet test a Marquis Reward today and was hoping to hear the advice that you will get. Otherwise, how do you like your spa? Thanks and good luck with your water problem.
IonHeaven
treviso
« Reply #3 on: July 10, 2004, 07:53:31 pm »
HI,
I am very happy with the performance of my Marquis Euphoria and being a newbie, I was just hoping to get some advice from some experts.  I wet tested both the Reward and Euphoria and settled on the larger Euphoria, but I really liked the Reward's performance.  The lounger and the amount of space that it takes up in the spa was the reason why I went with the Euphoria instead.  From what I have read, most people avoid loungers on their second spas.
Robert
Mendocino101
« Reply #4 on: July 10, 2004, 08:41:30 pm »
I am meeting with the spa frog folks this week...I will try and get you some information from them as the best way to care for you spa using the frog....
Lori
« Reply #5 on: July 10, 2004, 10:09:47 pm »
I'm sorry treviso, I don't use Bromine.  :-/
autoplay
« Reply #6 on: July 11, 2004, 09:10:54 am »
Get rid of brohmine.....and go with Di-chlor
