Author Topic: Sunbelt Spas  (Read 4087 times)
Boomer
Sunbelt Spas
« on: June 17, 2004, 10:46:14 pm »
Does anyone have experience with Sunbelt Spas? They are built in Houston
Sunbelt Spas
Rboehme
Re: Sunbelt Spas
« Reply #1 on: June 18, 2004, 10:19:01 pm »
Never heard of them. Do they have a website?
Boomer
Re: Sunbelt Spas
« Reply #2 on: June 20, 2004, 12:10:50 am »
ndabunka
Re: Sunbelt Spas
« Reply #3 on: June 20, 2004, 01:03:42 am »
I know sunbelt quite well. They are a primarily a shell builder. They also sell their units completely finished.  A local retailer here typical buyer the Sunbelt and then will customize the jets for you. It's a GREAT way to get into a tub with a lot of jets for under $5K. Be warned however that there is little or NO insulation in these puppies so they do cost more to run in the winter. If your in the southern US they aren't a bad choice since temps here are more moderate. If your up north you would need to figure a way to add insulation to the sunbelt units.
Re: Sunbelt Spas
