Author Topic: 2000 Sundance/Sweetwater Bahia FL1 problen  (Read 3564 times)
mdezeeuw
« on: September 07, 2013, 06:04:54 pm »
Went out last week and my circuit board was fried where it goes out to my heater. The pumps would work but no heat and a flashing FL1 on the display. Installed my new board #6600-288 (was a #6600-278) and i still have the FL1, So I put in a new filter, replaced the flow switch, purged all the air out of the lines, looked for stuff in the pumps that may be restricting flow and all clean. I turned off the breaker for 2 hrs and clicked it back on and the display reads FL1 before the pumps kick on. When the pumps kick on, the heater will turn on an heat but the pump stays on for only 20 min and doesn't keep going to the temp I want it at.
When the circ pump starts the FL1 goes away it is only when they are off it goes back to FL1.
What do you guys think. I am at a total loss and out of ideas.
Mike
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
Re: 2000 Sundance/Sweetwater Bahia FL1 problen
« Reply #1 on: September 09, 2013, 10:27:49 am »
I believe in 2000 the Bahia did not have a circulation pump.  Is the heater a 2" wide tube right behind the control box?  If so, you need a 5.xx chip on your circuit board, not a 3.xx.  If the chip on the old board is 5.xx, you can just swap that out with the chip on the new board.
mdezeeuw
« Reply #2 on: September 09, 2013, 10:56:14 am »
Wow, I thank you for the info.I will do that when I get back into Town Saturday. My old board has the 5.56 chip in it and the new one is 3.?? Can't remember. It look like from a pick have on my phone it looks like the chip will just pull out.
mdezeeuw
« Reply #3 on: September 15, 2013, 01:19:13 pm »
SerjicalStrike,
Thank you so much! I put the other chip in it and it is working great!!!
Thank you !
Mike De Zeeuw
