Sign up
Log in
It's HOT...
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Welcome to our forum.
Home
Help
Search
Login
Register
Brand Specific Forums
Jacuzzi Hot Tubs
Leaking manifold Jacuzzi J-355
« previous
next »
Print
Pages: [
1
Author
Topic: Leaking manifold Jacuzzi J-355 (Read 6272 times)
dennisoates
Junior Member
on:
August 04, 2013, 02:40:40 pm »
The leak is at the blue line more towards the center of the pic ,at a coupling. How do I remove this and repair this major leak, it is from ice damage I think. It is packed with foam and I removed quite a bit. Do I have to cut a hole in bottom of the base to access this area,? This is on the manifold and there are 8 lines attached to this and its a tight area. any tips or suggestions would be appreciead.
http://www.flickr.com/x/t/0095009/photos/rainbowtawas/9438083570/
Last Edit: August 04, 2013, 02:47:23 pm by dennisoates
Logged
on:
Ultimate Member
Re: Leaking manifold Jacuzzi J-355
Reply #1 on:
August 04, 2013, 03:41:46 pm »
Your tubs only 2 years old why don't you call your dealer, and you seem to be the original owner, not bought from some lady??
Logged
TwinCitiesHotSpring
Full Member
Reply #2 on:
August 04, 2013, 03:53:31 pm »
if it is in fact at the coupling on what appears to be rigid pipe its going to be a severe pain in the you know what...you going to have to dig it back as far as possible and cut it with probably a "wire saw" in order to fit new couplings and a piece of flex pipe in there
Logged
dennisoates
Junior Member
Reply #3 on:
August 04, 2013, 03:58:53 pm »
ice damage is not covered by warranty Jim
Logged
Ultimate Member
Reply #4 on:
August 04, 2013, 06:45:31 pm »
Quote from: dennisoates on August 04, 2013, 03:58:53 pm
I'm not entirely sure you have freeze damage there. Usually when/if I see freeze damage it's at the pump housing/ pump unions or heater housing. Not buried in foam at a manifold/connection. And freeze damage is most times a big crack, not a drip, from a glue joint.
Logged
dennisoates
Junior Member
Reply #5 on:
August 04, 2013, 08:52:35 pm »
good point maybe they will warranty it, the pic don't show it , but the coupling is split /broke, all the way around
Logged
Reply #5 on:
Print
Pages: [
1
« previous
next »
Jacuzzi Hot Tubs
Home
Buying Guide
Featured Products
Forums
Reviews
About
Contact
Copyright ©1998-2026, Whats The Best, Inc. All rights reserved. Site by
Take 42
