Author Topic: please help me diagnose the problem!  (Read 3247 times)
nlv81
« on: January 29, 2013, 09:24:57 pm »
I have a leisure bay hot tub. It has been working great until recently. When I turn on the power, it will stay on for a few seconds but as soon as the jets kicks on. The fuse blows out. I replaced the fuse & the same thing happened. What could be the problem? I hope its a easy & inexpensive fix b/c I really miss my hot tub :( thank you in advance
Re: please help me diagnose the problem!
« Reply #1 on: January 30, 2013, 09:38:26 am »
Welcome to the forum.  We have lots of experts here, but till they come along, can you take the panel off and have a look?  I'm technically competent, but no real experience as a hot tub professional.  Do you have more than one pump? I had a similar situation. My tub had 2 pumps. I was able to unplug one pump from the main board and still use the tub till I had it fixed.  Frequently visual inspections will provide some obvious clue.
nlv81
« Reply #2 on: January 30, 2013, 03:15:13 pm »
Yes, I have taken off the panel & tried to see if there's any damage wires or parts. Everything seems to look fine. I believe my hot tub only have 1 pump. Thank you wmccall for your help.
« Reply #3 on: January 30, 2013, 05:21:31 pm »
 My best guess would be that pump on the left, looks like it's has a leak or the leak is from somewhere else?   Also looks like there is/was water coming under the control box.    Just un plug that pump and see if it stays on..    Looking at the other side is there a pump behind the box as well?   Prolly where the water is coming from also.     You might have bad shaft seals that are dripping then spraying when the pumps come on.
« Last Edit: January 30, 2013, 05:23:59 pm by Jacuzzi Jim »
Dr. Spa™ Ret.
« Reply #4 on: January 30, 2013, 07:28:32 pm »
Looks like there's a pump behind the box (there's a union behind the pressure switch) ...also the main electrical conduit has become unattached(1st picture, top left of box) which could be a serious electrical problem, as the wires could be cut by the box and short out, or cause electrocution.
