Author Topic: New help, no power at tub  (Read 20721 times)
Re: New help, no power at tub
« Reply #15 on: March 09, 2012, 03:09:03 pm »
  It can be hit and miss with elements.     If after replacing the breaker and it still trips you can unhook the power leads to the element and fire the spa up.   If the spa trips it's not the heater, if it doesn't trip it probably is the heater. Then hook the heater back up and hit the power if it trips there is a 95% chance it's a bad heater.
  Still could be a few other issues causing the breaker to trip but the heater is a good start.
mkrozell
« Reply #16 on: March 09, 2012, 03:15:30 pm »
That's exactly what i was going to do. Thank you for confirming for me
Dr. Spa™ Ret.
« Reply #17 on: March 09, 2012, 05:55:57 pm »
A bad heater element is the MOST common cause of a breaker tripping.
mkrozell
« Reply #18 on: March 09, 2012, 06:02:10 pm »
If it does indead end up being the heater, would you suggest just putting a new element in the manifold or by a new manifold also?
mkrozell
« Reply #19 on: March 10, 2012, 06:51:08 pm »
Problem seems to be fixed now. Been running for the last hr and still going. Breaker was the problem. Thanks again for all the help. Now time to drain and clean
« Reply #20 on: March 10, 2012, 07:53:21 pm »
  Nice!!
