Author Topic: Help guys  (Read 5952 times)
Bonibelle
  • '05 Marquis Epic
Help guys
« on: August 26, 2011, 08:10:16 am »
OK, so Irene will be paying me a visit Saturday into Sunday Please someone tell me how to tie my cover down..My tub is on a deck..I don't want it to land in OZ...but I have no idea of how to secure it for a hurricane! :o :-[
Help guys
Darnovi
Re: Help guys
« Reply #1 on: August 26, 2011, 09:21:38 am »
One quick fix is to screw 4 eye bolts into your deck (one on each side of your hot tub) then run some lightweight cable across you hot tub in each direction fastening each end to a bolt. After storm bolts can be removed holes filled with a wood filler and sealed.
ejf The Spa Guy
  • THE SPA GUY
Re: Help guys
« Reply #2 on: August 26, 2011, 12:17:59 pm »
they do make straps for covers that go from one side of the spa to the other, typically 2 to a pack. or like preciously mentioned use eye bolts, but you can also use ratchetting straps, i would recommend putting cardboard at the edges of the cover under the strap..
Bonibelle
  • '05 Marquis Epic
Re: Help guys
« Reply #3 on: August 26, 2011, 12:33:19 pm »
Thanks so much guys..on my way to the hardware store now.. :)
Re: Help guys
« Reply #4 on: August 26, 2011, 01:41:06 pm »
If your had bought an Arctic tub, they would send the entire staff over to stand on your cover during the storm  :D ;D
Dr. Spa™ Ret.
Re: Help guys
« Reply #5 on: August 26, 2011, 03:49:24 pm »
I think I might consider just turning off the spa and taking the cover inside. Much easier to deal with cleaning the spa, than either buying a new cover, or figuring out how to keep in from blowing across the country.
Bonibelle
  • '05 Marquis Epic
Re: Help guys
« Reply #6 on: August 26, 2011, 09:38:06 pm »
I thought of that too Doc, I have a leaf net that I can throw over the spa to keep out the big stuff..Maybe that would be the best idea. I have the straps and eye bolts..but maybe I will do the net...Got both kids off to college today, so I will have to think about this early tomorrow morning. :-\
Re: Help guys
« Reply #7 on: August 27, 2011, 11:04:07 am »
I like Doc's idea a lot, but if you want to tie down - I would use straps, not cables. The cable will eat through cardboard in a flash, even faster once the cardboard is wet.
And if you really want to batten it down, put a couple sheets of plywood over the top and then winch it down. Trim to fit, so the edges don't stick out and grab the wind.
http://www.harborfreight.com/2-inch-x-20-ft-ratchet-tie-down-47764.html
Re: Help guys
« Reply #8 on: August 27, 2011, 11:05:39 am »
Oops - looks like you already have the idea of straps - good. Let us know how things go!!
Bonibelle
  • '05 Marquis Epic
Re: Help guys
« Reply #9 on: August 30, 2011, 11:47:50 am »
I used those straps, Chas, and eye bolts in the deck (they can actually stay and not impact anything). The cover stayed in place but I just got power this morning, so I have to go kick the tub back on and see what it looks like on the inside... ;) Thanks for the suggestions..that was easy for me to do and now I am ready for the next one...
Re: Help guys
« Reply #10 on: August 30, 2011, 06:16:42 pm »
Awesome! Any other damage to your property?
Bonibelle
  • '05 Marquis Epic
Re: Help guys
« Reply #11 on: August 30, 2011, 06:48:55 pm »
No, I feel really blessed! Leaves, branches and lots of water, but everything is fine after a day of cleaning up. My sister even arrived with a little Honda generator and saved my freezer and fridge!
Chas, you know a lot about all kinds of stuff...I want to buy a generator, do you have any suggestions? All I need to do is run my refrigerator, freezer and a light...This little Honda was awesome and very quiet,  but I think it is probably pretty expensive.  Thanks  :)
Re: Help guys
