Author Topic: electrical question 6ga. vs. 8ga need opinions  (Read 4329 times)
buffalopaul
« on: March 22, 2011, 02:12:43 am »
I have a 40 amp ground fault breaker outside my house for my old tub.  I bought new tub and i am going to convert to 50 amp.  I currently have 8ga wire running from gfb to spa (approx 5ft). General electric code is to use 6 ga for 50 amp.  However my new manual says to add a junction box and reduce to short lenghts of 8ga.  Can i just use my existing 8ga from the gfi to the spa (5 ft)?
BNMac
Re: electrical question 6ga. vs. 8ga need opinions
« Reply #1 on: March 24, 2011, 12:39:45 pm »
I'd say it depends.  If you do it right, you'd change the 8ga to 6ga for the entire run.  6ga wire isn't expensive for those lengths.
That said, the other factor is the potential power draw from your new tub.  If it draws anything over 40A with everything running, then I'd suggest upsizing the wires.  If it'll never draw over 40A, then you can get by with your existing wire.
Our tub will never draw over 40A, but the manual said to use #6.  If #8 is used, and there's a problem, the warranty will be void.  This particular tub has other options that would push the amp draw over 40A, which is why it's worded as such.
The wire run from our GFI to the tub is 20', even though the GFI is only about 7 feet away.  Per code, the GFI must be at least 5' away from the tub... so how could you have a 5' run of 8Ga wire from your GFI to the tub's junction box?
buffalopaul
« Reply #2 on: March 24, 2011, 05:49:35 pm »
I ended up taking out the 8ga wire and replacing with 6 ga when i changed out the gfi.  I started to think the same way you did after awhile.  I had it all ripped apart anyway so i might as well do it all.  I ended up going a little longer to get tub 5 ft from gfi.  Thanks for the advice
BNMac
« Reply #3 on: March 28, 2011, 05:16:01 pm »
Cool!  Have a good soak.
