Author Topic: Spa Pads?  (Read 6492 times)
mouth
Spa Pads?
« on: January 06, 2011, 10:38:15 am »
Anyone have any luck using Spa Pads? I live in Michigan, so it is not possible right now to poor concrete, but am thinking of getting a tub. ???
Spa Pads?
soak-king
    • Backyard Oasis
Re: Spa Pads?
« Reply #1 on: January 06, 2011, 12:50:35 pm »
We've used them on a few occasions with no problems. You just need a level area to put them, preferably sandy.
paulsimmons
Re: Spa Pads?
« Reply #2 on: January 06, 2011, 02:26:23 pm »
I haven't observed problems with them either.  I have a friend that has used them and been satisfied.
Spa Guy Dave
Re: Spa Pads?
« Reply #3 on: January 08, 2011, 08:23:20 pm »
I have used them on several ocassions and have been pleased with the results. As stated earlier, the ground surface must be level. I prefer the EZ Pad. It only has 4) 4'x4' Foot Pieces, which fasten together with strong brackets. The Ez Pad has a strong extruded design. You can build the base, then easily carry it to the proposed area or flip it over in place. Goodluck.
headnsouth
Re: Spa Pads?
« Reply #4 on: January 15, 2011, 10:33:52 am »
I framed out my area in 6x6 PT lumber and filled it with stone. It was a cheap and fairly easy install and movable if I ever need to.
Jet Sitter
Re: Spa Pads?
« Reply #5 on: January 15, 2011, 05:39:53 pm »
One of my neighbors with a tub says his wife always wears one when she gets in.
soak-king
    • Backyard Oasis
Re: Spa Pads?
« Reply #6 on: January 17, 2011, 11:05:37 am »
 :o ;D ;D   :-X :'(   ::) :D
LOL
rick_in_cleveland
Re: Spa Pads?
« Reply #7 on: January 21, 2011, 04:05:54 pm »
I've had my tub on an EZ pad for 6 years with no problem.  Just make sure you use construction grade sand as a base and not play sand
SpaGuy911
Re: Spa Pads?
« Reply #8 on: March 09, 2011, 09:27:00 pm »
Yes!!!! thats what i;m talking about
Re: Spa Pads?
