Author Topic: water hardness  (Read 2743 times)
Memories_Galore
water hardness
« on: November 12, 2008, 07:05:01 pm »
water hardness is my problem.  I added too much chemicals to bring it up, now I think it's too high.  It is at 600.  What can I do exept to drain some water and add plain water?  Any help, please.
Thanks in advance.
water hardness
Re: water hardness
« Reply #1 on: November 12, 2008, 07:59:23 pm »
You can drain some water out and refill.  ;)    You would probably be ok with it if you wanted to leave it and just use the tub refill as needed its up to you.
Memories_Galore
Re: water hardness
« Reply #2 on: November 13, 2008, 11:36:09 am »
Thanks for the info.  I think I will take your advice and just refill as needed.
tony
  • 2002 Optima
Re: water hardness
« Reply #3 on: November 13, 2008, 12:34:33 pm »
If you leave as is, be sure your pH does not get above acceptable levels as scaling can occur.
Memories_Galore
Re: water hardness
« Reply #4 on: November 13, 2008, 07:13:53 pm »
thanks for telling me about the PH level.  It's good for now, I will keep checking it.
Re: water hardness
