Author Topic: do I need to change the water  (Read 5093 times)
benalexe
« on: November 04, 2008, 03:24:33 am »
It has been since about June that i have the same water in my tub. THe water is crystal clear.  I don't use it very much maybe once every 2 weeks at this point.   Do I need to changed the water prior to winter.
I have an ozone systemn and put about 2 oz dichlor every week in the tub.
Chad
  • 2006 Jacuzzi J-345
Re: do I need to change the water
« Reply #1 on: November 04, 2008, 07:48:20 am »
I would.
NE-Phil
  • Marquis Reward '05
« Reply #2 on: November 04, 2008, 08:15:12 am »
I would.
because...
Not a mountain lake? Then it's still a chemical soup!
Mr._Bubbles
  • Tiger River Bengal-HP
« Reply #3 on: November 04, 2008, 08:32:46 am »
because...
Maybe because the water is already six months old and it’s a lot easer and safer to change it now instead of the middle of Winter. :-?
« Last Edit: November 04, 2008, 08:33:16 am by Mr._Bubbles »
It's all about da bubbles!
« Reply #4 on: November 04, 2008, 08:34:05 am »
I would say yes,
Your CYA is probably over 300 (probably closer to 500) and with winter approaching the best time to change would be now. 4 months is about the top end of how long you should keep the water. You don't want to have to change the water on a 10º day.
Water is the best chemical you can add to a tub!
Chad
« Reply #5 on: November 04, 2008, 08:41:41 am »
Thanks Mr. B.  I didn't feel like stating the obvious. :)
Brothersean
« Reply #6 on: November 04, 2008, 09:24:17 am »
Absolutely  YES because of  Above!!!
  Sean
Bonibelle
  • '05 Marquis Epic
« Reply #7 on: November 04, 2008, 09:54:36 am »
Benny...another new wonderful experience for you..Fresh clean water. My analogy is crisp clean sheets right off the clothes line. So I agree, dump that 5 month old water and enjoy a soak in fresh, crisp water..it's almost as nice as a mid winter soak!!! ;)
Mr._Bubbles
« Reply #8 on: November 04, 2008, 12:51:44 pm »
Oh yes, there is nothing like a clean fill.  It realy does feel differant.
@ Chad - I knew you were holding back... ;)
« Last Edit: November 04, 2008, 12:52:32 pm by Mr._Bubbles »
benalexe
« Reply #9 on: November 04, 2008, 08:35:19 pm »
Well here is another question.  The other times I have drained my tub I get an air lock in my 3rd pump which means I need to unscrew the panels remove the insulation and unscrew the pump union. A real pain in the neck.
Any advise on how to avoide the air lock?  Can I empty half the water and re-fill?
« Reply #10 on: November 04, 2008, 09:11:04 pm »
Bingo, if he can easily make it 6 months, changing now takes him into May.
Chad
« Reply #11 on: November 05, 2008, 09:41:49 am »
Benalexe,
After you refill your spa, start it up w/o the filters installed and make certain that there is absolutely no debris in the water. I've never tried it but I know a few members who do this successfully.
« Reply #12 on: November 05, 2008, 12:03:50 pm »
Definately change the water out.   And to avoid air lock, are you filling the tub through the filter well? (put the garden hose down into the filter well standpipe)
And yes, you can empty half the water and refill.  Folks who live in frigid climates and find themselves with bad water in the middle of Feb, the partial water change out can be a good fix.
« Last Edit: November 05, 2008, 12:04:32 pm by drewstar »
Hillbilly Hot Tub
« Reply #13 on: November 05, 2008, 12:55:04 pm »
1/2 draining the water will only drop the high CYA level down half and will creep back up quickly. When the CYA level is high, the chlorine you add is not effective. Drain all the way and try the suggestion of filling via the skimmer, this may or may not help. If that particular pump does not draw water through the skimmer it won't help. You can try draining down to the suctions and leave the water level up over those, then you are getting most the water out, more than a 1/2 drain and allowing the water to stay in the pumps. Good Luck......
benalexe
« Reply #14 on: November 05, 2008, 05:27:17 pm »
Thanks, I think I will drain to right above the suctions,  then I will fill up again maybe half way again and drain to above the suctions again.  I think this should do it.
I just hate opening the cabinet if I don't have to.
FYI how do you check the cya?
