Author Topic: Bubbles/Foam  (Read 3810 times)
SDCPL858
Bubbles/Foam
« on: June 11, 2008, 06:27:23 pm »
We've had our HS Prodigy for a lil over a week and use it daily. When we turn the jet selector to one position it makes the water foamy like? Switch to the other position the bubbles/foam goes away? Any suggestions? My water tests come out perfect. Thanks.
Bubbles/Foam
Spiderman
Re: Bubbles/Foam
« Reply #1 on: June 11, 2008, 06:48:34 pm »
When we get foam in our tub, it seems like depending on where we're sitting and what position the diverter valve is in, the foam is drawn into the filter compartment.  Hope this makes sense.  8-)
Merlin
  • Just here to help.
Re: Bubbles/Foam
« Reply #2 on: June 11, 2008, 07:40:27 pm »
Yes what Spiderman said does happen. I would recommend rinsing off your filter.
A good thing to remember to do before you use the spa is to jump in the shower and JUST RINSE it helps to get a lot of the oils off of your body before they get in your spa.  8-)
Merlin
Knowledgeable, Friendly, Helpful and Award Winning Hotspring & Caldera Dealer in Southern California
SDCPL858
Re: Bubbles/Foam
« Reply #3 on: June 12, 2008, 04:15:21 pm »
I'm not sure what rinsing off has to do with it as it only happens when we put the diverter in one location? One position it's fine, another position and we get foam/bubbles turn it back to the other position and the foam/bubbles disappear?
Re: Bubbles/Foam
« Reply #4 on: June 12, 2008, 05:25:25 pm »
Are you sure you're not using the air selector control ... it looks like a diverter valve on my tub except smaller.
SDCPL858
Re: Bubbles/Foam
« Reply #5 on: June 16, 2008, 03:07:56 pm »
I was told that my Prodigy did not have an air pump? It is the diverter handle located right were you step into the spa. It gererates a lot of foam/bubbles and then you switch it over and the foam/bubbles disappear? :o
tony
  • 2002 Optima
Re: Bubbles/Foam
« Reply #6 on: June 16, 2008, 05:22:58 pm »
The air selector valve is not for an air pump, but is a venturi valve that allows outside air to be drawn to the jet to give a different action.  From your description, you are turning this valve on and off.  When air is supplied to the jet, there is a stronger jetting action and fine air bubbles comming from the jet itself.
SDCPL858
Re: Bubbles/Foam
« Reply #7 on: June 16, 2008, 06:56:24 pm »
Ok I gotcha, yea it turns off some jets and turns others on when you turn it.
Re: Bubbles/Foam
