Author Topic: Chemistry 101?  (Read 13777 times)
Swell-Tub
  • Scott
Chemistry 101?
« on: April 26, 2008, 07:27:18 pm »
Now that my spa search has come to a close, and we have some new spa owners on the horizon. I have not understood all the shocking chemical talk going on. What will I need to know to keep my new hot spot in the Desert from becoming a stink hole?
I have figured out that I will need to drain the tub every three months. I know there is some test strips I need to dip. I hear that I need to throw a plugged in toaster into the spa to shock it every so often. So what will become my daily, weekly, monthly routine?
Thanks in advance,
Scott  :-?
2008 Jacuzzi J-470
Chemistry 101?
Re: Chemistry 101?
« Reply #1 on: April 26, 2008, 07:53:42 pm »
First you're going to need to decide if chlorine or bromine is to be used. Either way these are the 2 main sanitizers.
Both are easy to use but I would say that if you use your tub every day or every other day then dichlor is probably the best out of the two.
Check the water's parameters on a weekly basis adjust if neccessary, shock with either chlorine or MPS weekly or at least every other week. If you decide to shock with chlorine you need 10x free chlorine of the combined chlorine amount (TC+CC+FC). [size=16]<--- SHOULD BE: TC=CC+FC[/size]
Other than that you need to clean the filters on a monthly basis.
Thats about it.
« Last Edit: April 27, 2008, 07:39:49 pm by Vinny »
Swell-Tub
  • Scott
Water Hose Pre Filter?
« Reply #2 on: April 26, 2008, 10:03:01 pm »
I see that many people use a garden hose filter to put water in their spa's. Is there one kind or brand that is better than others?
Scott  :-?
2008 Jacuzzi J-470
Re: Chemistry 101?
« Reply #3 on: April 27, 2008, 08:34:44 am »
I can't say as I don't use one. Honestly don't know what they're for.
Micah
Re: Water Hose Pre Filter?
« Reply #4 on: April 27, 2008, 11:28:14 am »
Scott  :-?
Although some people might need it, you probably don't .  You are getting a Jacuzzi J-470.  The "Polishing" filter is made of the same filtering agent as most "pre-filters".  Your filtration system will take out as much in the first 60 seconds of filtering as a pre filter would.
 As for the choice of chlorine vs bromine I am going to respectfully disagree with Vinny on this one.  IMO Bromine is a much better choice.  With chlorine you will have to add chemicals several time a week.  with bromine most people add every 7-10 days.  Your J-470 comes standard with a bromine dispenser inside the filter compartment.
 One thing to look for in bromine is "100% chlorine free" bromine.  Most bromine is diluted with chlorine to keep the price down.  If it is "True Bromine" it will say 100% chlorine free
Jacuzzi, Hot Springs and Caldera dealer in Los Angeles
« Reply #5 on: April 27, 2008, 01:51:07 pm »
Isn't the bromine feeder for bromine pucks? I thought 100% bromine was only in powdered form ... learn something new every day!
tony
  • 2002 Optima
« Reply #6 on: April 27, 2008, 07:01:41 pm »
I know that the Brilliance bromine product is 100% bromine and has its own feeder system.  For bromine pucks that do not include chlorine, what do they use with the bromine to make it a slow dissolving puck?
Micah
Re: Chemistry 101?
« Reply #7 on: April 28, 2008, 01:08:05 am »
Brillance comes in a pellet form that works great with the feeder on the 400 series
Hillbilly Hot Tub
Re: Chemistry 101?
« Reply #8 on: April 28, 2008, 02:45:08 pm »
I personally use the Brillance bromine system and love it. it does not have the smell that the bromine/chlorine tablets do. They have a sytem that is very easy to follow, and I have had no issues with this sytem and I even "abused" it, ie: let it go longer than I was suppose to, not adding stain and scale, over shocking and under shocking, just to see what this chemical system did.( I knew some customers would not follow full instructions, so I wanted to see what happened) No big issues even doing that. I would look into it, and as Micah said, chlorine is very much more labor intensive.
tony
  • 2002 Optima
Re: Chemistry 101?
« Reply #9 on: April 28, 2008, 02:58:16 pm »
I wonder if it would work in the Sundance feeder that is in the filter weir?  I've seen a picture of the Brlliance feeder that you can attach inside the filter area.  Is that the pellet form you are referring to?
Re: Chemistry 101?
« Reply #10 on: April 28, 2008, 03:14:03 pm »
...I know there is some test strips I need to dip. I hear that I need to throw a plugged in toaster into the spa to shock it every so often. ...Thanks in advance,
Scott  :-?
I really hope you are joking.  Honeslty, (and don't mean to be rude here) but throwing a toaster  into a pool of water to "Shock it"  is asinine.
W. T. F?
to properly shock a tub, you sneak up on it, and annouce:
"I am Terminators and Bonniebells illegitmate love child!"
That will sufuccinelty shock the tub.  ;)
Swell-Tub
  • Scott
Re: Chemistry 101?
« Reply #11 on: April 28, 2008, 03:32:39 pm »
WHAT??? I'm shocked.......
2008 Jacuzzi J-470
Re: Chemistry 101?
« Reply #12 on: April 28, 2008, 04:11:28 pm »
Although I have never used bromine, to classify using chlorine as "very much more labor intensive" is a little of a misinformation. What's the difference of shocking before or after soaking with bromine or adding chlorine before or after soaking? Same amount of work. I would imagine that either system needs to be looked after weekly and things adjusted if need be. Unless this Brillience doesn't need shocking to re-activate the bromine.
If you use the tub often then there is no difference. The difference is when you don't use the tub often then bromine wins hands down. On the plus side of chlorine - there is nothing more powerful besides flourine and ozone to kill organisms ... florine is lethal and ozone is questionable in the quantities that we are talking here. Bromine can't do the killing/clearing job of chlorine even after 3 months of use with the exception of the hot tub itch bacteria ... don't know how long it takes for bromine to kill it, chlorine won't kill it after 50 PPM CYA.
I found that brilliance doesn't require the shocking before or after use as the pucks do ... how long does a 5 lb jug last? 5 lbs of chlorine lasts about a year for me in a 400 gallon tub.
« Last Edit: April 28, 2008, 04:24:50 pm by Vinny »
Micah
Re: Chemistry 101?
« Reply #13 on: April 29, 2008, 02:23:32 pm »
1.5 lb of brillance last between 3-5 month.  5lb should last about a year.   Most people on brillance shock every 7-10 days when they refill the bromine dispenser
Re: Chemistry 101?
« Reply #14 on: April 29, 2008, 03:35:29 pm »
Can the mermaid dispenser be refilled?
Re: Chemistry 101?
