Author Topic: What Brand Of Pump Is This?  (Read 4047 times)
Spiderman
« on: May 17, 2008, 10:14:45 am »
I've got a guy who needs to replace the wet end on his 2 speed pump from a '98 Sundance Marin.  It's a 2.5hp  "Theramax"  2-speed  230v   L56Z frame motor and it says Emerson on it, model R611863A.  The Sundance pump model # is 061201932 and he thinks it is an Aqua Flow pump.   What wet end will work with this pump?  Thanks
Hillbilly Hot Tub
Re: What Brand Of Pump Is This?
« Reply #1 on: May 17, 2008, 10:27:56 am »
check the frame on the motor, make sure it is a 56 frame. this would be unusual on a 1998 tub. Measure the bolt patteren to see if it is 48 or 56 frame. Any wet end will fit with the correct bolt patteren.
