Author Topic: Swirl Away  (Read 5507 times)
Brookenstein
Swirl Away
« on: February 28, 2008, 08:52:17 pm »
I am running the tub with swirl away in it right now.  After I drain it, do I fill it up and drain it again, then fill for good?  Is there any secret to making sure I get all the stuff out?
Swirl Away
Re: Swirl Away
« Reply #1 on: February 28, 2008, 08:58:34 pm »
I'd just go by the directions and just in case it doesn't say, make sure your air controls are closed while the pumps are on high speed. You shouldn't have to refill twice after the application my dear.
Brookenstein
Re: Swirl Away
« Reply #2 on: February 28, 2008, 09:11:54 pm »
I couldn't tell from the directions if I was suppose to drain and refill again or not.
Richs100
Re: Swirl Away
« Reply #3 on: February 29, 2008, 07:27:53 am »
I know what you mean, Brooke.
When the bottle says "Lather, Rinse and Repeat", I can never get out of the bathroom.
maybe its just the OCD.....   :) :)
Re: Swirl Away
« Reply #4 on: February 29, 2008, 08:10:56 am »
And don't run your neck jets on high if they are above the waterline. I think I had a pile of foam that was 6 foot high.
tony
  • 2002 Optima
Re: Swirl Away
« Reply #5 on: February 29, 2008, 08:59:14 am »
There is no need to fill and drain again.  That would make the process way too burdensom to be worthwhile.  You can rinse the sides down while it is draining or when it is drained.  Then just close the drain valve and fill.
Running the jets with the air venturis open with Swirl Away can be hazardous  ;).
Re: Swirl Away
« Reply #6 on: February 29, 2008, 08:59:40 am »
I don't think it's necessary to fully fill and drain.  If I recall, all I did was to rinse down the insides really well, including the filter compartment,  and what didn't go down the drain, I sucked out with a shop vac.  At most I used an extra 20 gallons of water.
 Even with my air valves shut, no filters, etc...  It was pretty amazing how high the foam went.  Wish I'd taken a photo.
Brookenstein
Re: Swirl Away
« Reply #7 on: February 29, 2008, 12:34:35 pm »
Well, I drained anyway...I didn't want to risk any foamage.  It needed a good cleaning.  I was actually surprised I didn't get more foam.  I swear I was getting that much foam when I tubbed lately, lol.  Maybe the foam and the swirl away counter balanced each other, lol.  Anyway, I'm full again and at 63*.  Too bad it won't be warm before I leave for boy scout camp today.   :'(
Re: Swirl Away
« Reply #8 on: February 29, 2008, 02:27:55 pm »
Keep the jokes clean please.  ;)
Richs100
Re: Swirl Away
« Reply #9 on: February 29, 2008, 03:38:55 pm »
Now, that was funny!!
Re: Swirl Away
« Reply #10 on: March 01, 2008, 01:46:09 pm »
What ever in the world do you mean, Bill?
How could Brooke's comment be in any way made the subject of a joke?
Re: Swirl Away
