Author Topic: Just ordered a Hot tub cover from  (Read 12857 times)
104 degrees
« on: October 17, 2007, 07:31:32 am »
rhtubs.com. Its the extream standard with the double wrap foam.
I'll let you know how it goes and is when we get it.
Thank s john 104 Degrees :) :)
Re: Just ordered a Hot tub cover from
« Reply #1 on: October 17, 2007, 08:22:35 am »
Please do share.  I've been putting off a cover purchase wayyyyy to long, and Doc is the likely place I'll do business.
Hopefully before winter............................(just like I said last year)
104 degrees
« Reply #2 on: October 17, 2007, 09:17:52 am »
I'm like a hungry man waiting for a Pizza to be delivered ;D
westgate
« Reply #3 on: October 17, 2007, 02:33:35 pm »
Hello I live in the Northeast (long Island). What density should get for my 4' - 2" tapered cover that i will be ordering from either spacovers.com or rhtubs.com?
1 lb ??
1.5 lb ??
2 lb ??
which site do you reccomend to order from?
Dr. Spa™ Ret.
« Reply #4 on: October 17, 2007, 08:41:00 pm »
which site do you recommend to order from?
Geez, I must be doing something wrong. Ok. lets do a quick comparison....
feature - rhtubs.com - spacovers.com
price : $320 - $340
foam density 1.5 - 1.25
vapor barrier : 6mil - ???
warranty : 4 years - 3 years
tie downs : 4 - 2
Continuous hinge seal : yes - no
Residential Delivery Fee : $0  - $18
price : $320 - $340
westgate
« Reply #5 on: October 18, 2007, 07:50:01 am »
thanks Doc! so RH it is for me.
Is 1.5 density good enough for cold winters or should I go with 2 lb density?
« Reply #6 on: October 18, 2007, 09:18:41 am »
Same here.  A friend bought one and it looks good. I'll also go with the double wrap.  My 2nd cover in 5 years ia starting to get a bit heavy.
Dr. Spa™ Ret.
« Reply #7 on: October 18, 2007, 02:30:08 pm »
2 pound density foam will only increase the R value by 1 (one). The biggest advantages are more strength (30% more) for snow load, and the denser foam is less susceptible to water absorption.
104 degrees
« Reply #8 on: October 18, 2007, 02:40:53 pm »
price : $320 - $340
tie downs : 4 - 2
price : $320 - $340
This would have sold me :) opppsss it did ;D
« Reply #9 on: October 18, 2007, 03:01:03 pm »
Water absorbtion has been my big problem.  Would the denser foam and double wrap be over kill?
Did you see my aqua check test strip order go through?  I worded it so someone might have pointed it out to you.
« Reply #10 on: October 18, 2007, 03:26:31 pm »
That double wrap would totally be worth it if it kept water absortion at bay a few extra years.  My cover is in excellent physical condition, it just weighs a ton cause it's soaked up all that water.
Dr. Spa™ Ret.
« Reply #11 on: October 18, 2007, 04:10:04 pm »
Personally, I think the double wrap is enough, but I"m lazy and don't want to lift a cover that weighs 25%-30% more.
Sorry, I never saw the order. Most likely it came in during a time I wasn't here (I'm currently telecommuting / compucommuting quite a bit these days)
104 degrees
« Reply #12 on: October 24, 2007, 02:45:45 pm »
Its starting to get colder :) it should be ariving soon :)
Neptuner
  • My only tub foam
« Reply #13 on: October 25, 2007, 01:03:03 am »
My cover is 4 years old. The top looks it but inside it looks brand new and there has been zero water absorption. I expect my cover to last at least 2 more years.
I have a good quality floating blanket.
104 degrees
« Reply #14 on: November 23, 2007, 03:03:38 pm »
Word on the street is-----Tuesday from noon to four i will have my cover. i'll take pics before and after. :)
