Author Topic: Is this method of chemicals overkill?  (Read 13991 times)
hottubdan
Re: Is this method of chemicals overkill?
« Reply #15 on: October 02, 2007, 05:06:32 pm »
The Stain and Scale is protection.  It does not bring down the hardness.
squale
« Reply #16 on: October 02, 2007, 05:09:20 pm »
so that explains why they said to put stain and scale in once per week...  is there any products that actually REDUCE the hardness?
tony
  • 2002 Optima
« Reply #17 on: October 02, 2007, 06:24:36 pm »
No.  Only diluting with low calcium water.
squale
« Reply #18 on: October 02, 2007, 07:35:06 pm »
Well my Aquatest strips are reading in the 300ppm range, but it just says HARDNESS, does that automatically mean Calcium hardness?
what's weird is that on the back of the Aquacheck bottle it says the OK range is like 250-400 or something for Hardness..
but on my BioGuard print out and the stain and scale bottle it says the OK hardness is 100-150ppm
so this doesn't make sense to me, are we comparing apples to apples?
tony
  • 2002 Optima
« Reply #19 on: October 02, 2007, 07:39:28 pm »
That's calcium hardness.  Generally speaking, 100-250 for acrylic, fiberglass or vinyl pools, spas; 250-400 for plaster (concrete) pools.  You should be OK at 300 with your stain and scale.
squale
« Reply #20 on: October 02, 2007, 07:40:33 pm »
and so basically people like me with hard well water once hte water goes into the spa it will ALWAYS be hard, you just need to use the stain and scale chemical to protect the components from scale buildup?  or do most people with hard water actually try to dilute the water with soft water (no idea where they are supposed to get that amount of soft water from?)
tony
  • 2002 Optima
« Reply #21 on: October 02, 2007, 07:50:47 pm »
Some people with water softeners will mix half and half.  100% soft water is not good for a spa.  Whatever you do, don't use one of the pH lock products with the calcium you have.
hottubdan
« Reply #22 on: October 02, 2007, 07:58:24 pm »
You really don't need to worry about your hardness.
Use the Stain and Scale.
Keep your pH in range.
High pH will cause calcium to precipitate out of the water...you won't like that/ :-/
squale
« Reply #23 on: October 02, 2007, 08:10:47 pm »
well after shocking 3 hours ago, it is now at ph of 8.8, free chlorine is 9.5 and alk is UP to 227 (not sure why the Alk and PH rose higher after putting the PH Decreaser in there?)
tony
  • 2002 Optima
« Reply #24 on: October 02, 2007, 08:21:00 pm »
Did you have these high pH and alk numbers when you used bromine?  Could be what caused your rash.
squale
« Reply #25 on: October 03, 2007, 08:23:48 am »
well they weren't AS high, and they certainly come down rather quickly when I put PH Decreaser in.  This morning, I just checked and here are my numbers..
PH = 8.7
Free Chlorine = 3.5
Alk = 260
So the Alk actually went UP and the PH Stayed about the same from yesterday, this is AFTER I put PH Decreaser in.  I wonder if since I used bleach to clean the tub before I drained it, if any of that bleach was still in the pipes and might of been affecting the PH?  not sure, but I'm very surprised that the PH and Alk are actually still the same and going UP!
hottubdan
« Reply #26 on: October 03, 2007, 09:18:23 am »
How much pH decreaser did you add?  With TA that high you need a lot. :o
squale
« Reply #27 on: October 03, 2007, 10:32:15 am »
I added 2 ounces yesterday, 2 ounces this morning.  It's a 385 gallon tub.
hottubdan
« Reply #28 on: October 03, 2007, 12:29:27 pm »
Not nearly enough to knock dow your TA.  I don't have my charts here but I'm guessing you need at least 10 ounces.
Add 5 oz.  Mix for 15-30 minutes.  Repeat.  Test.  Add more as needed.
You small amounts will not be enough to make a difference.
squale
« Reply #29 on: October 03, 2007, 01:25:32 pm »
is it bad to add too much in one day?  I was told to add 1 ounce per day for 7 straight days.. not sure why they say to do it in little bits each day?
