Author Topic: Need help with a water union gasket....sizing?  (Read 3777 times)
emt1581
« on: June 17, 2021, 01:58:44 pm »
I've got one of the inflatable Saluspas, the Paris model.  I the gasket for the water union is shredded.  I'm seeing it may not be a standard sizing.  Internally it's ~1.5" and externally it's ~1.75" in diameter.
Any idea what the specific part/sizing is and maybe where I can find it?
I'm guessing I can order one from Bestway (parent company) but they'll charge me $40-$50.  I'd like to see if I can find a better one, maybe silicone, aftermarket.
Thanks!!
Re: Need help with a water union gasket....sizing?
« Reply #1 on: June 17, 2021, 07:04:02 pm »
One of your local pool/spa stores will likely have one for a ton less. Use silicone based lubricant to extend it's life.
emt1581
« Reply #2 on: June 18, 2021, 12:26:20 pm »
Stopped into the local pool/spa shop.  Got some sideways looks and was told those parts for the inflatables are really brand-specific and they had nothing remotely similar.
Silicone-based lube....I have cases of Uberlube which is a high quality silicone lube, but it's meant for sex.  Will that work?  Silicone is silicone...no?
« Reply #3 on: June 18, 2021, 05:34:09 pm »
Ummmmmm I guess so, LOL the stuff we used to use was Magilube made for that.
https://www.amazon.com/Silicone-Grease-Valves-Gasket-Rings/dp/B01LQKC0AA/ref=asc_df_B01LQKC0AA/?tag=hyprod-20&linkCode=df0&hvadid=507808886860&hvpos=&hvnetw=g&hvrand=12920249755845525295&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019772&hvtargid=pla-1253564467560&psc=1
« Reply #4 on: June 18, 2021, 08:06:29 pm »
Cases?
emt1581
« Reply #5 on: June 18, 2021, 11:48:29 pm »
Cases?
They're sent to my practice quarterly.
