Author Topic: @ease test strips  (Read 4498 times)
guardrail22
@ease test strips
« on: May 01, 2018, 11:33:59 am »
which did you get from dealer and what do you use now?
@ease test strips
d00nut
Re: @ease test strips
« Reply #1 on: May 01, 2018, 11:54:38 am »
Not sure if I understand?
If you are using @Ease, I do recommend using their test strips.  Because the amount of chlorine is so darn low in the @ease system, I find many other types of test strips don't pick up the chlorine reading.
If for pH, I'm sure you can use pretty much whatever you want
guardrail22
« Reply #2 on: May 01, 2018, 01:40:06 pm »
well if the pictures had arrived from google photos that would help
trying again
d00nut
« Reply #4 on: May 01, 2018, 01:48:06 pm »
Not working:
404. That’s an error.
The requested URL was not found on this server. That’s all we know.
The Wizard of Spas
« Reply #5 on: May 01, 2018, 05:46:52 pm »
Are you asking:  When you bought @ease, what were the strips that came with it, and if you have since used different test strips, what do you use now?
If that is indeed the case-  I'd stay on the @ease strips until you perfectly understand A) @ease and B) what a different, generic test strip will be asking for and how that may not necessarily translate to your sanitation system.
A generic test strip will tell you that your TOTAL CHLORINE is galactically high if you use them in an @ease body of water.  If you understand that indeed the level is okay, and *why* it is okay, then buying generic is fine.  If you also understand why the FREE CHLORINE is ridiculously low, then you're fine too.  If these are questions that you do not understand the *why* behind them, I'd stick with @ease test strips.
guardrail22
« Reply #6 on: May 03, 2018, 04:40:35 pm »
One more time.
https://ibb.co/dCLndn
https://ibb.co/dxWtJn
Using the ones in blue bottle.
Want the ones in bottle with green top
guardrail22
« Reply #7 on: May 03, 2018, 04:42:56 pm »
guardrail22
« Reply #8 on: May 03, 2018, 07:43:20 pm »
guardrail22
« Reply #9 on: May 03, 2018, 07:54:35 pm »
The links work but the pics won’t show up even using recommended host.
d00nut
« Reply #10 on: May 03, 2018, 09:09:53 pm »
For pH, ALK, and CH, any of those work.
For the chlorine, I would stick with the @Ease strips.  Just easier
guardrail22
« Reply #11 on: May 04, 2018, 01:57:12 pm »
Three different @ease strips.
Trying to find the one with green lid
« Reply #12 on: May 04, 2018, 02:18:30 pm »
Only one of those is actually for @ease.  Frog offers multiple water treatment systems.  Only the ones that say "@ease" are for that program.  The blue bottle is a totally different company.  The one with the green lid is for a different program.  In the end, it doesn't really matter.  They will all work.  It's just that as stated above, smartchlor is a low level and some strips have trouble reading that low.
guardrail22
« Reply #13 on: May 07, 2018, 03:53:23 pm »
the issue with the one marked @ease is it just has a square on it that tells you everything is fine if you match that color.
the one with the green cap bottle is free, total, ph and total alk.
« Reply #14 on: May 09, 2018, 01:45:16 pm »
They all test ph and total alk.  You don't need to worry about free/total with @ease.  Smartchlor self-regulates as long as ph is in line.
