Author Topic: Deep freeze delivery  (Read 7350 times)
silversun
« on: December 19, 2017, 07:05:17 am »
I'm taking delivery next week but the forecast is extremely cold in the northeast (~15 degrees).
I'm concerned about the process of taking delivery, getting it wired up, filling, and finally heating the tub in those conditions. Seems like the margin for error is much smaller than taking delivery over the summer.
I'm completely new to hot tubs. How concerned should I be of freeze up? Any advice from the experts?
« Last Edit: December 19, 2017, 07:08:13 am by silversun »
Beck0101
Re: Deep freeze delivery
« Reply #1 on: December 19, 2017, 10:54:48 am »
Considering your tub is not likely traveling to you in a heated truck from the manufacturer I would assume it will be fine outside until you get power to it.
Don't put any water in it until she's fully wired up.  After that you should be good to go.
« Reply #2 on: December 19, 2017, 06:06:54 pm »
I've delivered about a dozen tubs In The last 2 weeks. Had one slight issue with a circ pump that got some ice trapped in it. I believe it only happenned because the tub sat outside for a little over a week before the electrician could make it. I'm a bit south of you maybe 50 miles or so, so weather should be similar. Make sure to coordinate electrician same day or day after Tub gets delivered and you will be fine. As far as heating I just filled and started up a tub on the water in Cape Cod. By the morning it will be up to temp. Keep your hose in the house so it's not frozen when you go to fill it
silversun
« Reply #3 on: December 20, 2017, 04:39:52 pm »
Thanks for the advice. I lined up the electrician for the same day.
I thought I had it all figured out, and of course the forecast is now calling for snow!
A Rai
« Reply #4 on: December 21, 2017, 10:57:57 am »
Put a space heater in the cabinet of the spa for like 3-4 hours BEFORE your electrician hooks it up, to thaw out any ice that may be in the pumps impeller preventing it from spinning. Just an extra measure to take before you go to try to turn it on and say "My pump doesn't work!"
silversun
« Reply #5 on: December 22, 2017, 10:00:26 am »
Thanks again. after checking the weather again, it's now expected to be 9 degrees that day, and below freezing the day after. Too cold to take the risk. So I ended up moving the delivery to the week after, when the temp is expected to be a little warmer, though likely still below freezing much of the day.
This is still kind of freaking me out so i've done a lot of research on it, including looking through a couple old wtb threats on this exact topic. As of now, here's my plan:
- Get the hot tub delivered in the morning between 8-9.
- place a space heater in the cabinet immediately, on low.
- Have the electrician scheduled for the same day to wire it up - (dealer suggests dry firing to test it).
- fill it with water, quickly. I plan to use semi-hot water from the inside tap (brought out in 5 gallon buckets and poured into the center footwell) combined with cold water from the outside garden hose going straight into the filter (I have a well, so the water is likely under 40 degees,, very cold). the semi-hot tap water should boost the temperature enough to get out of a scary fast freeze up time if something goes wrong, with the added benefit of allowing the tub to heating up faster. Filling from the hose directly through the filter should also prevent an airlock situation.
- ask electrician to stay during the process of filling in case anything goes wrong when switching on the power, since the 400 gallons should go by fairly quickly. I'm estimating about 30-45 mins since I have good water pressure and will be filling via buckets as well.
- turn it on, heat.
- exhale!!
SerjicalStrike
  • Reinstate Hank Williams!!
    • Great Bay Spa and Sauna
« Reply #6 on: December 22, 2017, 12:18:09 pm »
Do not dry test the electrical in freezing conditions.  If the pumps try to kick on and there is any ice in the impeller, the fuse may blow, or the pump may fail.
The space heater can be put on at least medium without any issues, and warmer is definitely better.
« Reply #7 on: December 22, 2017, 04:04:28 pm »
Be very mindful of the placement of the heater in your equipment bay. Don't start a tub bon fire in your yard.
Beck0101
« Reply #8 on: December 28, 2017, 07:44:24 am »
Have you talked to your dealer or the manufacturer about your concerns?  Hot tubs are delivered to northern climates all winter long.  Tubs are able to be winterized and pumps are able to be drained of water.  I'd be shocked if the manufacturer or dealer aren't taking care to ensure they can deliver in just about any weather conditions.
Better safe than sorry though I think you may be overthinking this...
countryboy
  • soak it in cider
« Reply #9 on: December 28, 2017, 10:18:01 am »
If u power it on dry the heater might burn out too.
silversun
« Reply #10 on: December 30, 2017, 01:38:43 pm »
I ended up pushing out delivery until Presidents day weekend in February - the next weekday I have off work and can be on site for delivery. There's an ongoing construction project at the property, which is directly above the hot tub, and affects the availability of water and electricity. Combine that with the frigid temps, and the fact that we are not even moved in there yet (though could have still used the hot tub since we're only a mile down the road), and its just not worth the risks.
I was in touch with the dealer and got some advice about using the space heater and turning it on dry for just a second and shutting it down before the pumps come on, which I'm told occurs around 15 seconds after turning it on. This 'quick-fire' is designed to test to ensure it's correctly wired up before filling it with water, without risking the pumps.
BullFrogSpasMN
« Reply #11 on: December 30, 2017, 02:43:57 pm »
deep freeze delivery, we did about 10 last week at around -5 below, you really just need to be more aware and make sure everything is coordinated with the electrician and the spa is filled properly to avoid an air lock so it can begin to heat right away.  The dealer should really be assisting so you aren't stressed about it...good luck
« Reply #12 on: December 30, 2017, 03:22:16 pm »
+1. I’m been delivering like crazy and we are having sub zero weather here
BullFrogSpasMN
« Reply #13 on: December 30, 2017, 05:10:30 pm »
Ya I've never sold so many spas in December before....economy seems to be doing good and people are def. spending money right now because our ASP's are way up as well, we're adding Smartops, Salt Systems, Stereo's, etc. at an incredible pace...love it!
Cora5
« Reply #14 on: December 30, 2017, 05:32:25 pm »
Hi BullFrogSpasMN, Just curious, what type of salt systems are you adding to your spas? I didn't realize that Bullfrog had a salt system in their spas.
